joshiler wrote:
> We have a remote office connectly by vpn over cable. They are unable to install 2008 civil3d and land desktop due to it crashing after trying to install after about 2 hours, i think it is an internet connection issue. What I have done is have them install from disk as a standalone and manually add a licpath.lic file and change the registry key to make it a network install. This seems to work fine for Civil3d, it is accessing a network license from our main office fine, but the Land Desktop companion isn't working. I keep getting the message a valid license cannot be obtained. I have checked to make sure the licpath.lic file is there and it is in the root directory on both, does something else need to be done to get ldd to work.
Are you trying the install over the VPN?
That isn't going to work, way too slow.
You can copy the deployment, change the path in the
shortcuts, then run the deployment locally.
Also, you don't need any .LIC files, just use the Windows
environment variable:
Example:
ADSKFLEX_LICENSE_FILE=@LIC1,@LIC2
R.K. McSwain
http://rkmcswain.blogspot.com
