Hi
I had been triying to intal the trial version of Revit 2014 and every time I do it it saids it has a Network failure.
Attach two images of the problem
Try to download from here
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links>Revit Products>Autodesk Revit
Please accept as a solution if this fully resolves the issue
DarrenP
