I have a network deployment image for ADT / Revit 2013 both 32 bit and 64 bit installs. I have a new computer / hardware that has a fresh install of windows 7 pro. Whenever I try to run the network deployment for either the revit image or autocad image the setup gets stuck cycling the setup initializing.
I have tried:
1. clean format install of os and same result.
2. Update windows 7 - try to deploy - same result.
3. Pre-install .net framework since I have read that can be an issue - same result
4. Install.net update it - test same result.
5. I have tried deploying it from local c with same result.
I cannot figure out why the network image is hanging on setup initializing.
The deployment location - has changed since it's original creation with hardware refresh but it's location is still the same drive letter and share.
I can deploy 2015 suite to the same hardware but since were in process - of migrating I need to deploy both versions.
When I check the deployment log the pc it is trying to deploy to never even logs that pc telling me it is not getting through the setup initialization which is in line with the dialog.
The network deploy is setup for silent mode.
Does anyone have any other suggestions to try?
