Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Network deployment CUI problem
- Highlight
- Email to a Friend
- Report Inappropriate Content
I am in the process of developing our network deployment for AutoCAD Map 3D 2012. All seems to work well, except that the custom cui file I specify (Z:\AcadUser\2012\Support\MAP-2012.CUIX) in the setup does not carry through in the installation and gets replaced with
C:\Users\burgessb2\AppData\Roaming\Autodesk\AutoCA
Is this a known error? is there a workaround for this?
Any help will be greatly appreciated.
Re: Network deployment CUI problem
- Highlight
- Email to a Friend
I should probably clarify that it is the main customisation file, not the custom cui file
- Highlight
- Email to a Friend
I have looked at the log file and found that it is setting it to the correct file, but then overwriting it with the c:
extract from log file
MSI (s) (98
0) [08:56:17:149]: Executing op: RegAddValue(Name=MenuFile,Value=z:\acaduser\2012\s
MSI (s) (98
0) [08:56:17:149]: Executing op: RegAddValue(Name=TempDirectory,Value=C:\Users\burg
MSI (s) (98
0) [08:56:17:149]: Executing op: RegAddValue(Name=GRIPSUBOBJMODE,Value=#0,)
MSI (s) (98
0) [08:56:17:149]: Executing op: RegAddValue(Name=MenuFile,Value=C:\Users\burgessb2
