• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    *D, Mike
    Network Monitor Errors & Acad2k File Locking Errors
    92 Views, 0 Replies
    10-26-2000 12:05 PM
    I posted this on the Microsoft news group and they were clueless. Our
    network seems to be functioning properely with the exception of DNS. Would
    an improper DNS set up mess up Autocad and cause the mysterious drawing
    going read only errors?
    I was using the network monitor to try and determine if our network was
    functioning properely. From the monitor everything looked ok. However I
    did a capture and saved it to disk. When I opened it I noticed many errors
    that looked like this:
    SMB: R transact2 - NT error, System, Error, Code =
    (52)STATUS_OBJECT_NAME_NOT_FOUND
    SMB: NT status code = 0xC0000034, Facility = System, Severity = Error, Code=
    (52) STATUS_OBJECT_NAME_NOT_FOUND
    The errors come after a previous frame listing :
    SMB: C transact2 Query path info, File =
    \Peterson\Original_File\Blockxref\Original_Files\ESORTdwk
    The errors seem to be associated with the lock files (.dwk) generated by our
    cad program (Autocad 2000i) which indicate when a drawing file is in use.
    This cad program has been misbehaving by files that are open for editing
    suddenly going read only. Does this reflect a network problem? I have had
    problems with large Adobe Photoshop files (50mb+) saving over the network
    and Quickbooks Pro 2000 is having great difficulty in multuser mode.
    We are running a complete Win 2000 network, server and workstation.
    Mike D
    Please use plain text.
