Installation & Licensing
merlin25
Message 1 of 3 (90 Views)
Network Liscence Fails in remote office
90 Views, 2 Replies
11-27-2000 08:39 AM
We have 2 offices. In the main office we have a computer designated without a static ip address that has the ADLM installed. It works fine in the main office for all to connect. In the other office it connect with the ACAD Variable connecting to the computer name solely allowing WINS to resolve the address. The first time each computer in this other office attempts to connect it gives the msg it cannot find the ADLM or assign liscence. But if you open the program a second time it then works. I have tried adjusting the timeout variable and that does not work.
We currently have 48 liscences to AD2000. We have designated a non server computer at this time and not a main server due to network congestion. Can anyone tell me what kind of Network congestion I can estimate for 48 Liscenses connecting to it. It is my understanding that a network liscence will ping that computer at a minimum every 6 minutes. Is that correct?
I would like to move the ADLM to one of our main servers that has a static IP address which I think could resolve the timeout issues in the other office the first time the program is opened becaue it would no longer need to rely on WINS to resolve it's location.
Also, on a non patterend scenario it seems as though the other office about 1 time a week will start failing to connect to the ADLM all togather. The oly solution has been to Reboot the ADLM. Will moving the ADLM to the main server resolve this problem? could the Setting for the ACADSERVER Variable be incorrect? The ACAD SErver Variable is currently configured to find the name of that computer and not it's IP.
Currently we run NT 4.0 Servers. The ADLM is on NT 4.0 Workstation. All 48 CAd stations run NT 4.0. The 2 office are on different subnets.
Any suggesttions or adives would be great.
THANKS!!!
Merlin
*Lawson, Robert
Message 2 of 3 (90 Views)
Re: Network Liscence Fails in remote office
11-28-2000 05:30 AM in reply to: merlin25
What if you loaded the ADLM on three machines? This might help availability,
and add some fault tolerance. Another benefit of going static IP is you can
use the IP address in lieu of the computer name in the ACADSERVER
environment variable. This probably saves a trip to the WINS server and
whatever traffic that is, plus may help since you have two subnets.
"merlin25" wrote in message
news:ef54406.-1@WebX.SaUCah8kaAW...
THANKS!!!
Merlin
*milana, jerry
Message 3 of 3 (90 Views)
Re:
12-05-2000 10:07 AM in reply to: merlin25
You should not use an IP address in the ACADSERVER value! Doing so is not
supported by Autodesk and in most networks will not work. Make sure that
you are setting the ACADSERVER value to the correct case as the wrong case
has been known to cause problems similar to what you describe. For example,
if your server hostname is "paradise", setting ACADSERVER to PARADISE would
cause problems. Don't confuse the NetBios Machine Name with the hostname.
The first is always set to upper case and the hostname by convention, should
be lower case. Best way to check is to look at the server's adlm.log file.
You will find a line that tells you the name of the system it has started on
(just search the log file for the word "started").
jerry milana,
Autodesk Product Support
"Robert Lawson" wrote in message
news:EAFDD9F52EE80BD88037EE085499BB1A@in.WebX.SaUCah8kaAW...
availability,
can
without
the
if
the
about
> THANKS!!!
> Merlin
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
