Installation & Licensing
Network License error [-15.570]
5 REPLIES 5
EvoSpyder
720 Views, 5 Replies
Trying to install our 2014 PDSP.
The NLM is up and running on our server and appears to have no issues. Shows that 3 licenses are available and 0 in use.
Clients cannot be activated however, with the message "A valid license could not be obtained by the network license manager" Error code [-15.570.0]
5 REPLIES 5
DarrenP
in reply to: EvoSpyder
a -15 error means your having communication issues between the client machines and the license server
can you ping the license server by host name?
DarrenP
EvoSpyder
in reply to: DarrenP
Yes, I can ping the license server from the client
DarrenP
i would check your firewall allow these ports
The FLEXlm® based version uses the following ports:
  • TCP ports 2080 (for the adskflex vendor daemon)
  • TCP ports 27000 to 27009 (for the lmgrd master daemon)
DarrenP
TravisNave
And don't forget about the IPv6 anomoly.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
EvoSpyder
Thanks Darren, I missed one of those in our server settings.
Administrator Productivity
