• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Altmix, Chuck L.
    Network License & Speed issues.
    135 Views, 3 Replies
    01-08-2001 06:00 AM
    Autodesk:
    We have been battling for quite some time with speed issues in AutoCAD 2000.
    We once thought it could be our customization or PC3 files but now we
    believe it could be an issue with the network licensing. Lets just say that
    all the network license copies installed throughout our office operate at a
    snails pace in spite of the fact they are running on some very high speed
    processors. The only 2 installs that seem to run at normal speed are those
    that were installed directly from the disk bypassing the network license
    server.
    We have a brand new lightning fast file server and PCs so I seriously doubt
    that it is our hardware....
    My question is: has there been any reported history or complaints of speed
    issues regarding a network license copy of autocad 2000. Also, could it be
    a combination of several factors including the network licensing server that
    could be slowing us down?
    Chuck Altmix
    Please use plain text.
    *Nehls, Kevin
    Re: Network License & Speed issues.
    01-08-2001 06:37 AM in reply to: *Altmix, Chuck L.
    I have no problems with network licenses.
    100Mbs switched network
    800MHZ with 512 MB RAM file server with all of our files plus AdLM
    PII 233MHZ with 128 MB RAM clients (here is the only slow part)
    We have full client installs, not network heavy installs. If you do have
    network heavy installs that will slow you down a bit, but it sounds like
    you're getting slowed down more than a network heavy installation normally
    would.
    You didn't tell us what kind of network you are on:
    Speed of network
    NOS (OS running on the server(s))
    file server specs
    apps running on AdLM server
    are the file server and AdLM server the same
    what type of installations
    client specs
    apps running on the client (antivirus software)
    Network protocol
    How are you specifying the AdLM server (ACADSERVER environment variable)
    ---- Try specifying this with @, where is
    your AdLM server's name
    HTH
    Kevin Nehls
    remove -ns- for direct reply
    *Altmix, Chuck L.
    Re:
    01-09-2001 10:25 PM in reply to: *Altmix, Chuck L.
    Kevin:
    Here is the data you
    requested...Thanks
    Chuck
    Speed of network
        100Mb mixed half and full duplex to a
    switch and hubs
    color=#0000ff>
        Novell v5.1 (files), WinNT v4.0 SP6
    (License Server)
    file server specs
    color=#0000ff>PIII800Xeon Compaq UltraSCSI-160 RAID 5 w/Gbit fiber to switch and
    640Mb RAM (files), PIII600 DELL w/ 256Mb RAM and 18GB RAID 5 100Mb full duplex
    switched (License Server)
    server
        SQL Server w/ very small
    database
    color=#0000ff>    No
    what type of
    installations
    client specs
        Upto
    PIII1000 Dell Dimension with 256 Mb RAM w/100Mbit connection
    apps
    color=#0000ff>
        Various including InoculateIT PE or Norton
    Antivirus 2000
    Network protocol
    color=#0000ff>    IP
    variable)
            ----  Try
    specifying this with @<adlmserver>, where <adlmserver> is
    your
    AdLM server's name
    @klingner-sql
    >I
    >100Mbs switched
    network
    AdLM
    part)
    >would.
    >You didn't tell
    >Speed of network
    >NOS (OS
    >file server specs
    server
    >what type of
    installations
    >client specs
    software)
    >Network protocol
    variable)
    >        ----  Try
    is
    >HTH
    >Kevin
    Nehls
    *Rizzo, Jon
    Re:
    01-30-2001 10:17 PM in reply to: *Altmix, Chuck L.
    YES! We have the same problem!! We have a similar setup, although our
    servers are all NT 4. I haven't been able to find any information about
    this. Any suggestions would be greatly appreciated.
    Jon Rizzo
    Langan Engineering and Environmental Services, Inc.
    "Chuck L. Altmix" wrote in message
    news:3BFC57454DB2868964F71F49C48297BC@in.WebX.SaUCah8kaAW...
    > Kevin:
    > Here is the data you requested...Thanks
    > Chuck
    > Speed of network
    > 100Mb mixed half and full duplex to a switch and hubs
    > Novell v5.1 (files), WinNT v4.0 SP6 (License Server)
    > file server specs
    duplex switched (License Server)
    > SQL Server w/ very small database
    > No
    > client specs
    > Upto PIII1000 Dell Dimension with 256 Mb RAM w/100Mbit connection
    > Various including InoculateIT PE or Norton Antivirus 2000
    > Network protocol
    > IP
    is
    > @klingner-sql
    > Kevin Nehls wrote in message
    <1E532F3DC34C844BCBFDAE1361419C49@in.WebX.SaUCah8kaAW>...
    y
    > >would.
    > >Speed of network
    > >file server specs
    > >client specs
    > >Network protocol
    is
    > >HTH
    > >Kevin Nehls
