you have to install AutoCAD on the workstation from a network deployment
tree.
1. Create a folder on your workstation and share it
2. Run setup.exe from the netsetup folder on the CD.
3. Select the shared folder for Deployment place
4. Answer all kinds of other questions
5. When asked for the license server, give the name of the server where Flex
is running and the ethernet address of the SERVER's networkadapter
6. After the "Deployment" is done, install the workstation from the
deployment folder with setup.exe
This is the only way to make AutoCAD 2002 look for networklicenses.
Cheers,
Petri Ahava
CAD-Q Finland
"jamie.holt" wrote in message
news:f10d140.-1@WebX.maYIadrTaRb...
> I am currently having problems getting AutoCAD 2002 to connect to my
AutoCAD license server. The FlexLM tools have been installed on NT Server
4.0 and I think the license is configured as a service correctly. My problem
is that although I have installed AutoCAD 2002 on Windows 2000 and added the
Environment Variable ACADSERVER, AutoCAD opens up in trial version asking me
to authorise the product.
> Can you help? If so drop me a line.
> Regards,
> Jamie Holt
