Installation & Licensing
Network License File Environment Variable Question
12 REPLIES 12
Message 1 of 13
1519 Views, 12 Replies
Hi:
Last week at AU I was told that I could somehow use ADSKFLEX in the environment variable, instead of LM_LICNESE_FILE, to aliveate some problems I was having when the client machine had other FlexLM software loaded on it. I am not sure how to do that - any insight would be appreciated.
Thanks;
Nick
12 REPLIES 12
Message 2 of 13
Hi Nick,
Use ADSKFLEX_LICENSE_FILE instead of
LM_LICENSE_FILE.  That will improve behavior in two ways.  First, the
setting only influences Autodesk products and this variable will override any
other server path setting for Autodesk Products.
Jerry Milana
Autodesk Professional Services
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hi:
Thanks;
Nick
Message 3 of 13
timsparks6941
Jerry,
Which location is ADSKFLEX_LICENSE_FILE to be placed...
HKEY_LOCAL_MACHINE\SOFTWARE\FLEXlm License Manager
or
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Session Manager\Environment
Thanks in advance...
Tim
Message 4 of 13
DarrenP
in reply to: timsparks6941
read this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8385605&linkID=9240617
DarrenP
Message 5 of 13
timsparks6941
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14374530&linkID=9240617
looks like both locations would be used...not sure why though.
Also, I'm getting conflicting info...ie on JTB, they state that you should use 27000@server instead of @server.
Tim
Message 6 of 13
DarrenP
i've only used @servername
never had a problem
DarrenP
Message 7 of 13
timsparks6941
I don't see a problem either, but is one faster than the other if the WAN is worldwide?
Message 8 of 13
DarrenP
it wouldn't hurt to test it on one machine
DarrenP
Message 9 of 13
TravisNave
The NLM connects to 27000 to lmgrd by default anyway, so it's not really going to make a difference.  On a WAN, you'll want to add the FLEXLM_TIMEOUT variable as well to overcome latency.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7574782&linkID=9240617
Autodesk Forums:
Message 10 of 13
timsparks6941
in reply to: TravisNave
yup...found that out and I have it set FLEX_TIMEOUT 1000000.
Thanks for the links as well...
Message 11 of 13
m.billep
I love it! Each time Autodesk relaunches their homepage non of the links work anymore.
I guess a few month ago this would have been a very helpful thread to me. And now?
Thanks Autodesk...
Mario
Message 12 of 13
TravisNave
in reply to: m.billep
Agreed. I am not a big fan of the change w/o appropriate redirects.  In any case, as complains come up, I will try to provide the new links:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-A...
Good Luck!
Autodesk Forums:
Message 13 of 13
m.billep
Thanks Travis!
Very kind and helpful.
Mario
Administrator Productivity
