Installation & Licensing
jeromefc
Message 1 of 6 (1,977 Views)
Network License [Error [-96.491.0]
1977 Views, 5 Replies
06-06-2011 03:22 AM
Error [-96.491.0] A valid license could not be obtained by network license manager Some of the suggestions that I did; 1. Renamed Cascadeinfo.cas (http://forums.autodesk.com/t5/Installation-Licensing/Licensing-Error-96-491-0/td-p/2699439) it didn't work. 2. Performed System variable settings (Go to: Start > Settings > Control Panel > System > Advanced > Environment Variables) eg. ADSKFLEX_LICENSE_FILE @servername 3. Disabled firewall (made an exclusion for ports 2080 and 27000~27009 ). In the end, I enabled firewall by default. 4. Modification of Hosts from the client located at C:\Windows\System32\Drivers\etc added the IP Address and Server name. (http://forums.autodesk.com/t5/Installation-Licensing/Invalid-License-for-Civil-3D-2010/td-p/2716215) These were the things that I’ve done. If you know any other solution(s). I would really appreciate it. Thanks, Jerome
DarrenP
Message 2 of 6 (1,971 Views)
Re: Network License [Error [-96.491.0]
06-06-2011 06:01 AM in reply to: jeromefc
a -96 error messages means: License server machine is down or not responding.
you may want to look at the license server side to see if its actually running
TravisNave
Message 3 of 6 (1,959 Views)
06-06-2011 09:33 AM in reply to: DarrenP
Yep, Darren is right.  I have been seeing this more lately on Server 2008 R2 where the adskflex.exe starts then stops but the lmgrd.exe service keeps running.  In most cases it turns out to be firewall and IPv6 related.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
jeromefc
Message 4 of 6 (1,899 Views)
06-20-2011 01:43 AM in reply to: jeromefc
Thanks a lot for the help. This is solved.
Valued Contributor
phil-mcam
Message 5 of 6 (1,570 Views)
12-14-2011 04:00 PM in reply to: jeromefc
I'm sorry, but I cannot see in this post what the solution is. For those of us unfamiliar with IPV4 vs IPV6 issues, could someone please elaborate?
I am getting this same type of error. Mine is Error [-96.7.2] and I can't get a license.
My license server is up and running, providing licenses to all who ask except this one machine. LM TOOLS reports having a license available for the software requesting it.
Machines that can pull licenses: Win7 64 brand new Dell laptop, and also older Vista 32bit HP laptops. No problem.
Machine not able to get license: brand new Macbook Pro. AutoCAD for Mac installed trying to pull a license for it. This machine is positively connected to the license server.
License server: XP Pro 2002, SP3
Any suggestions? And thanks for your time and consideration.
-Phil
Valued Contributor
phil-mcam
Message 6 of 6 (1,514 Views)
12-20-2011 09:30 AM in reply to: phil-mcam
Okay, I figured it out with a little help from Autodesk Tech support. So in the interest of anyone who can find this in a search string, here's the fix, in enumerated steps, very clear and specific, hopefully of actual use to someone in the future.
Mac unable to get license from server
1. We remove the Flexnet folder from the below location. These files can become corrupt and are automatically re-generated so can be removed for basic license issues / troubleshooting
/Library/Preferences/FLEXnet Publisher/FLEXnet/adskflex_00691b00_tsf.data
/Library/Preferences/FLEXnet Publisher/FLEXnet/adskflex_00691b00_tsf.data.backup
2. We could not connect to the server via Hostname so we used the IP address instead.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
