Installation & Licensing
TravisNave
Message 1 of 64 (36,680 Views)
Network License Error [1.5.-15] and IPv6
36680 Views, 63 Replies
04-07-2011 12:28 PM
PROBLEM: You launch your Autodesk product and receive a the FlexLM License Finder box and after specifying the License Server System, you are presented with the following error:
The network license manager was not able to get a valid license. If this problem continues, please contact your system administrator. Error [1.5.-15]
CAUSE:  Your Autodesk Network License Manager is installed on a Windows Server 2008 or Windows Vista/7 machine and/or your NLM and Autodesk product exist on the same workstation with IPv6 enabled.
RESOLUTION:  If your NLM and your Autodesk product are installed on the same workstation, verify that the connection made to the NLM is not via IPv6.  If so, disable IPv6 or redirect the protocol to use IPv4 instead.
Method #1:  Verify connectivity with your NLM server by opening a command prompt (Start > Run > CMD) and PING your server hostname:
A typical IPv6 response for localhost loopback when the NLM is on the same machine may be ::1 or it may be a full IPv6 address such as 3ffe:1900:4545:3:200:f8ff:fe21:67cf.  Your results may look different.  If the response is an IPv6 as in the picture above, then you need to disable IPv6 on your Network LAN settings and verify PING again to ensure it has an IPv4 address in the format of xxx.xxx.xxx.xxx.  For more configuration changes, continue on to Method #2.
For more information on how to disable IPv6 in Microsoft Windows Vista and 7, please see the following Microsoft KB support article:
http://support.microsoft.com/kb/929852/en-us
Method #2:  If you are unable to disable IPv6 or have a need for IPv6 on your network, then you can make a change to your system HOSTS file to redirect the protocol to use an IPv4 address instead.
Verify that connectivity to the NLM server is using IPv6 as described in Method #1.  If your response in an IPv6, then you need to edit your HOSTS file to point the server hostname to an IPv4 address instead.  You will need Administrative rights for this process.
First ensure that the User Account Control (UAC) in Windows is disabled.  Open the Control Panel and choose System and Security:
Then choose Change User Account Control settings:
Finally, disable the UAC option by setting it to Never notify:
Now you should be able to open and edit the Windows HOSTS file to make the necessary changes.  Find the file in the following location:
C:\Windows\system32\drivers\etc
Open the hosts file with Notepad.exe.  You should have Administrator privileges when performing this task.  If the file is Read-only, you may need to make the file writable from within the file properties dialog box.
Your HOSTS file should appear similar to the image below.
If your NLM and Autodesk product are on the same machine:
First, comment out the IPv6 localhost address of ::1 by adding a # sign.  Then add your hostname behind the IPv4 localhost 127.0.0.1 address as shown.  Save the file and close Notepad.
If your NLM is on a different server than your client installed software:
Create a new entry for your NLM server with the correct IPv4 xxx.xxx.xxx.xxx formatted address followed by your server hostname and save the file then close Notepad.
Verify IPv4 connectivity by opening the Command prompt and PING the server hostname.  It should now read the appropriate IPv4 response.  If your NLM is local, it should read 127.0.0.1.  If the NLM is on a server, it should read the IP address of your server.
Launch your Autodesk product.  It should now launch and obtain a license as appropriate.
For more information about Autodesk compatibility with IPv6, please see the following Autodesk Support KB article here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13107015&linkID=9261340
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
TravisNave
Message 2 of 64 (36,660 Views)
Re: Network License Error [1.5.-15] and IPv6
04-07-2011 12:35 PM in reply to: TravisNave
Help Improve the Autodesk Discussion Groups
If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems.
Member
jpresigjr
Message 3 of 64 (36,648 Views)
04-07-2011 01:44 PM in reply to: TravisNave
@Travis,
I appreciate your help but even after following your instructions, my issue persisted.  I am going to start from scratch in the hopes that I just goofed somewhere on the install.  I'm sure the problem was in my set up and not your help.  I will comment back later if I get up and running or if the issue continues for some reason.
Thanks again.
Valued Contributor
john.de.leeuw
Message 4 of 64 (35,824 Views)
07-06-2011 09:20 AM in reply to: TravisNave
Travis, thanks for this solution, it worked perfectly for me :smileywink:
Cheers,
John
TravisNave
Message 5 of 64 (34,303 Views)
09-14-2011 10:27 AM in reply to: TravisNave
I wanted to provide another update to this issue that can sometimes be addressed with the LICPATH.LIC file located in the root folder of your Autodesk application.  Modifying this file in a text editor such as Notepad can result in similar behavior as provided above.  Simply replace the NetBIOS hostname with the IPv4 address of the NLM server to resolve connectivity.
For more information about this file and more, please see the following link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14374530&linkID=9240617
Valued Contributor
suryawanshimohan
Message 6 of 64 (34,140 Views)
09-22-2011 12:11 AM in reply to: TravisNave
Dear Travis,
           I am also facing the same prob. I did edited the host file on server as you showed in this post. And it did worked for only server not the client PC's. Previously revit was not working on server also.
            Do i have to edit the host file on client Pc also. Please see attached screenshot of my edited server file. Please explain how to make run revit on client PC's it still gives the same error [-15.570.0].
mohans
TravisNave
Message 7 of 64 (34,101 Views)
09-22-2011 06:46 AM in reply to: TravisNave
Yes. If your clients are Win Vista/7 then they will also connect via IPv6. You will need to modify the hosts file to point to the correct IP address of your NLM server. Then verify with ping.
Additionally in the license finder box, you can put the IP address of the server also.
Just remember that 127.0.0.1 is the localhost so you will be using a different address on your clients' hosts that match the server's real IPv4 address.
Valued Contributor
suryawanshimohan
Message 8 of 64 (33,899 Views)
Re: Network License Error [1.5.-15] and IPv6 - This Solution Accepted.
09-30-2011 12:48 AM in reply to: TravisNave
Thanks a lot Mr. Travis. It worked for me i edited the host file's from both server & client PC's. Can you please elaborate on the license box, from where i will get this box also whicch IP address (server's or Client's) i have to add and where. Thanks again for your support.
Best Regards,
Mohan Suryawanshi-AE
TravisNave
Message 9 of 64 (33,883 Views)
09-30-2011 01:49 PM in reply to: suryawanshimohan
If the client can't find the NLM, it should prompt the license finder box similar to the graphic listed at the top of this thread.  Glad you are up and running.
Member
bsell
Message 10 of 64 (31,552 Views)
01-23-2012 09:42 AM in reply to: TravisNave
Took a while to get my head wrapped around the entire idea, but in the end it worked perfecty and now program is running.
Thanks alot.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
