I have recently installed NLMTools and depolyed my 50 user Licence file which all seems to work.
I then created a Deployment using the installer interface with Network Licence selected with the correct KEY and Licence server selected.
After installation on a workstation it throws up the error
The security system (softlock license manager)
is not funcioning or is not properly installed.
When I run cad on the system I can see it acquiring licence from the LMTools log.
this might be a permissions issue
can you run it as a full admin on that machine?
DarrenP
you may need to do a reinstall of the software if the above doesn't work
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22093011&linkID=9240617
DarrenP
I am the administrator and selected Run as Administrator but nothing seems to work, I have tried installation multiple times with no luck.
I have also tried installing as a standalone copy but get Activation error 123 whilst trying to activate it.
