I agree completely with TravisNave and his assessment of redundant servers. The other issue with redundant servers is that you may not even know when one of the servers goes down. Unless you're actively monitoring the three servers, you likely won't be aware that one has failed and you're now running with only two servers – one server failure away from being completely down.
Other than a redundant server model, you can't configure multiple servers running the exact same pool of licenses. A distributed server model would at least let you spread the licenses across two servers and then, if one fails, you'll know about it right away and the other server could still be serving licenses. That could help hold you over until you bring the failed server back on line.
Tom Stoeckel
Autodesk Product Support
Tom Stoeckel
Technical Lead, AutoCAD Product Support
Autodesk, Inc.
