Installation & Licensing
Network Installation for C3D License Manager 2012
4 REPLIES 4
esciences
1929 Views, 4 Replies
I have a team of engineers, I have a few servers, I have no clue how to set up AutoCAD license manager via the network. 🙂
So this is what I have currently setup and need to replicate:
Independent server running the license manager services with a license file for C3D2011.
We just upgraded to C3D2012, so I need to update the license manager, reinstall, reconfigure, whatever it takes.
Couple Issues of concern:
1) downtime, if I upgrade the license manager /license will my C3D 2011 notice anything?
2) I have a nifty .ini file that setups the whole AutoCAD install for me but for C3D 2011, how do we make one that's license/ serial number/ server specific?
Thanks for your time.
4 REPLIES 4
hashim.mundol
in reply to: esciences
1.It is recommended to close the program as, especually if there is change in license code or major version change, program will be denied the license and forced for a restart
If its only minor restart Program will continue running without noticing the license server restart.
2.Not sure about your INI, the SN,license server specification etc. are similar to AutoCAD for Civil3d.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
esciences
This is what the shortcut that uses the ini looks like:
"\\path\SETUP.EXE" /qb /I \\path\2011C3D64b.ini /language en-us
So this is simple enough, run program with this configuration file.
This is what the ini looks like:
[SETUP] SETUP_CODE={D54FD115-XXXX-XXXX-XXXX-XXXXXXXXXXXX} TITLE=AeccSetupRes.dll;10 LOG=%tmp%\AutoCAD Civil 3D 2011 Setup.log EVALMSI=SetupRes\eval.msi PRIMARY_MSI=C3D\C3D.msi SETUP_ICON=SetupRes\c3d.ico
SYSUPDATE=MSI x86_IMAGE_PATH=x86 x64_IMAGE_PATH=x64 RESOURCE_PATH=%lang%\SetupRes
LPMODE=NO_ADD_LP DEFAULTMEDIALANGUAGE=en-us
DOCUMENT_LINK=SetupRes\InfoLink\Documentation.html SUPPORT_LINK=SetupRes\InfoLink\Support.html SETUP_HIGHLIGHT_COLOR=#DD0000
SUMMARY_FUNC=LoadSummary_ACAD SUMMARY_SOURCE=SetupAcadUi.dll
README_FILE=SetupRes\InfoLink\Documentation.html
#==================== Platform Requirement
OSMAJVER=5 OSMINVER=1 SPMAJVER=2
#==================== Install Execute & UI Sequence EXE_SEQUENCE=C3D;ADR;VAULT INSTALL_SEQUENCE=ADR;C3D;VAULT UI_SEQUENCE=BeginDeploymentDlg;ProductSelectionDlg;LicenseDlg;UserInformationDlg;DeploymentSettingsDlg;ConfirmSetupDlg;C3D;ADR;VAULT;NLM;CADM;FullProgressDlg;InstallCompleteDlg;DeploymentCompleteDlg;DeploymentFailedDlg
#==================== UI
TOPBANNER=%setupuilang%\SetupRes\AcadSetupTopBanner.bmp SETUP_LOGO=SetupRes\acadlogo.gif ADSK_LOGO=SetupRes\adsklogo.gif UI_MODE=BASICUI
#==================== AdLM ProdKey Info
ADLM_CONFIG_FILE=AutoCADCivil3DConfig.pit ADLM_PIT_DLL=adlmPIT.dll ADLM_VERSION=2011.0.0.F ADLM_TRIAL_DAYS=30
#==================== Deployment Info
DEPLOYMENT_NAME=2011C3D64b CLIENT_LOGGING=YES EXTRA_FILES=acad;*.manifest:*.dll:*.exe:*.pit:*.xml:*.mlm:*.mc3:CER:eula:msi:NLSDL:%platform%\setupres:%platform%\C3D\Content:x64\en-US\Support\ADR
#==================== Global MSI Properties DEPLOYMENT_LOCATION=\\Servorl\static\Software Library\AutoDesk\C3D\11\64b DEPLOYMENT_PLATFORM=x64 NETWORK_LOG_PATH= NETWORK_LOGGING=NO SETUP_LANGUAGES=en-us
[GLOBAL_MSI_PROPERTIES]
#==================== Common UIs: install mode
[LaunchDlg] UI_CREATOR=LaunchDialog UI_SOURCE=SetupAcadUi.dll
[ProductSelectionDlg] UI_CREATOR=ProductSelectionDialog UI_SOURCE=SetupAcadUi.dll UI_INFO_LINK=SetupRes\InfoLink\Select_the_Products_to_Install_%s.xml.html
[LicenseDlg] UI_CREATOR=LicenseDialog UI_SOURCE=SetupAcadUi.dll UI_CONDITION=NOT ADSK_OEMPREINSTALL
[UserInformationDlg] UI_CREATOR=UserInfoDialog UI_SOURCE=SetupAcadUi.dll UI_CONDITION=ADSK_LAUNCH_MODE<>"TOOLS" AND NOT ADSK_OEMPREINSTALL UI_INFO_LINK=SetupRes\InfoLink\User_Information_Page.xml.html
[ConfirmSetupDlg] UI_CREATOR=ConfirmSetupDialog UI_SOURCE=SetupAcadUi.dll
[SelectPreferencesDlg] UI_CREATOR=PreferencesDialog UI_SOURCE=SetupAcadUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="STANDALONE" UI_INFO_LINK=SetupRes\InfoLink\Select_Preferences_Page.xml.html
[LicenseTypeDlg] UI_CREATOR=LicenseTypeDialog UI_SOURCE=SetupAcadUi.dll UI_INFO_LINK=SetupRes\InfoLink\License_Type_%s.xml.html
[InstallTypeDlg] UI_CREATOR=InstallTypeDialog UI_SOURCE=SetupAcadUi.dll UI_INFO_LINK=SetupRes\InfoLink\Installation_Type_Page_ACAD.xml.html
[FullProgressDlg] UI_CREATOR=FullProgressDialog UI_SOURCE=SetupUi.dll UI_INFO_LINK=SetupRes\InfoLink\Full_Progress_Page.xml.html UI_INFOTAINMENT_PATH=SetupRes\Infotainment\ACAD UI_INFOTAINMENT_ELAPSE=25000
[InstallCompleteDlg] UI_CREATOR=InstallCompleteDialog UI_SOURCE=SetupAcadUi.dll UI_CONDITION=ADSK_LAUNCH_MODE<>"DEPLOYMENT" UI_INFO_LINK=SetupRes\InfoLink\Installation_Complete_Page.xml.html
#==================== Common UIs: deploy mode
[BeginDeploymentDlg] UI_CREATOR=BeginDeploymentDialog UI_SOURCE=DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" UI_INFO_LINK=SetupRes\InfoLink\Begin_Deployment_Page.xml.html
[DeploymentSettingsDlg] UI_CREATOR=DeploymentSettingsDialog UI_SOURCE=DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" UI_INFO_LINK=SetupRes\InfoLink\Write_to_Log_Page.xml.html
[DeploymentCompleteDlg] UI_CREATOR=DeploymentCompleteDialog UI_SOURCE=DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" AND ADSK_SETUP_SUCCEEDED UI_INFO_LINK=SetupRes\InfoLink\Deployment_Complete_Page.xml.html
[DeploymentFailedDlg] UI_CREATOR=DeploymentFailedDialog UI_SOURCE=DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" AND NOT ADSK_SETUP_SUCCEEDED UI_INFO_LINK=SetupRes\InfoLink\Deployment_Complete_Page.xml.html
#==================== Common UIs: maintenance mode
[MaintenanceDlg] UI_CREATOR=MaintenanceDialog UI_SOURCE=SetupAcadUi.dll UI_CONDITION=NOT ADSK_OEMPREINSTALL
[AddRemoveFeaturesDlg] UI_CREATOR=AddRemoveFeaturesDialog UI_SOURCE=SetupAcadUi.dll UI_CONDITION=NOT REINSTALL="ALL" AND NOT REMOVE="ALL" AND NOT ADSK_OEMPREINSTALL UI_INFO_LINK=SetupRes\InfoLink\Add_Remove_Features_Page.xml.html
[RepairDlg] UI_CREATOR=RepairDialog UI_SOURCE=SetupAcadUi.dll UI_CONDITION=REINSTALL="ALL" AND NOT ADSK_OEMPREINSTALL UI_INFO_LINK=SetupRes\InfoLink\Repair_Product_Page.xml.html
[MaintVerifyReadyDlg] UI_CREATOR=MaintVerifyReadyDialog UI_SOURCE=SetupAcadUi.dll UI_CONDITION=NOT ADSK_OEMPREINSTALL UI_INFO_LINK=SetupRes\InfoLink\%s_Product_Page.xml.html
[MaintCompleteDlg] UI_CREATOR=MaintCompleteDialog UI_SOURCE=SetupAcadUi.dll UI_CONDITION=ADSK_SETUP_SUCCEEDED AND NOT ADSK_OEMPREINSTALL UI_INFO_LINK=SetupRes\InfoLink\Update_Complete_Page.xml.html
[MaintFailedDlg] UI_CREATOR=MaintFailedDialog UI_SOURCE=SetupAcadUi.dll UI_CONDITION=NOT ADSK_SETUP_SUCCEEDED AND NOT ADSK_OEMPREINSTALL UI_INFO_LINK=SetupRes\InfoLink\Maintenance_Failed_page.xml.html
[OemPreinstallLicenseDlg] UI_CREATOR=LicenseDialog UI_SOURCE=SetupAcadUi.dll UI_CONDITION=ADSK_OEMPREINSTALL="1"
[OemPreinstallUserInformationDlg] UI_CREATOR=UserInfoDialog UI_SOURCE=SetupAcadUi.dll UI_CONDITION=ADSK_OEMPREINSTALL="1"
#==================== ACAD Prerequisite
[OS] PRODUCT_NAME=Windows PRODUCT_MESSAGE=SetupRes.dll;210 VC_FUNC=AcadOsVerCheck VC_SOURCE=SetupUi.dll VC_PARAM=5.0.0;3.0 VC_DESCRIPTION=Detecting Windows EXE_PARAM=
[IE] PRODUCT_NAME=Internet Explorer PRODUCT_MESSAGE=SetupRes.dll;209 VC_FUNC=IeVerCheck VC_SOURCE=SetupUi.dll VC_PARAM=6.0.2800 VC_DESCRIPTION=Detecting Internet Explorer EXE_PARAM=
[SSE2] PRODUCT_NAME=SSE2 Support Check PRODUCT_MESSAGE=SSE2 Support Check VC_FUNC=CheckForSSE2Support VC_SOURCE=AcSetup.dll VC_DESCRIPTION=SSE2 Support Check EXE_PARAM=
[MSI] PLATFORM=ALL PRODUCT_NAME=Windows Installer Redistributable EXE_PATH=msi EXE_PARAM=/quiet /norestart ROLLBACKABLE=YES VC_FUNC=MsiVerCheck VC_SOURCE=SetupUi.dll VC_PARAM=4.5 VC_DESCRIPTION=Detecting MSI DISKCOST=200000
[DOTNET] PLATFORM=ALL PRODUCT_NAME=.NET Framework Runtime 3.5 SP1 EXE_PATH=support\dotnetfx\wcu\dotNetFramework\dotNetFx35setup.exe EXE_PARAM=/q /norestart VC_FUNC=DotnetVerCheck VC_SOURCE=SetupUi.dll VC_PARAM=3.5.30729.1 VC_DESCRIPTION=Detecting .NET Runtime 3.5 SP1 DISKCOST=80000000 IGNORE_FAILURE=YES PATCHES=
[DOTNETUPDATE] PLATFORM=NATIVE PREREQUISITE=KB958481;KB958483 PRODUCT_NAME=.NET Framework 3.5 SP1 Update KB958484 EXE_PATH=support\dotnetfx\update\NDP35SP1-KB958484-x86.exe EXE64_PATH=support\dotnetfx\update\NDP35SP1-KB958484-x64.exe EXE_PARAM=/q IGNORE_FAILURE=YES VC_FUNC=AcKB958484Check VC_SOURCE=AcSetup.dll VC_PARAM=3.5.30729.1 VC_DESCRIPTION=Detecting .NET Framework 3.5 SP1 Update KB958484 PATCHES=
[KB958481] PLATFORM=NATIVE PRODUCT_NAME=.NET Framework 2.0 SP2 Update KB958481 EXE_PATH=support\dotnetfx\update\NDP20SP2-KB958481-x86.exe EXE64_PATH=support\dotnetfx\update\NDP20SP2-KB958481-x64.exe EXE_PARAM=/q IGNORE_FAILURE=YES VC_FUNC=AcKB958481Check VC_SOURCE=AcSetup.dll PATCHES=
[KB958483] PLATFORM=NATIVE PRODUCT_NAME=.NET Framework 3.0 SP2 Update KB958483 EXE_PATH=support\dotnetfx\update\NDP30SP2-KB958483-x86.exe EXE64_PATH=support\dotnetfx\update\NDP30SP2-KB958483-x64.exe EXE_PARAM=/q IGNORE_FAILURE=YES VC_FUNC=AcKB958483Check VC_SOURCE=AcSetup.dll PATCHES=
[VBA] PRODUCT_NAME=VBA Runtime EXE_PATH=support\VBA\vba6.msi IGNORE_FAILURE=YES DISK_LABEL=C3D2011_64_Bit DISK_PROMPT=AeccSetupRes.dll;50
[VBALANG] PRODUCT_NAME=VBA Runtime Language Pack EXE_PATH=support\VBA\vba6%lang%.msi EXE_LANGS=2052,1028,1031,1034,1036,1040,1041,1042,1043,1046,1053 IGNORE_FAILURE=YES DISK_LABEL=C3D2011_64_Bit DISK_PROMPT=AeccSetupRes.dll;50
[DIRECTX] PRODUCT_NAME=DirectX 9.0 Runtime EXE_PATH=..\support\DirectX\DXSETUP.exe EXE_PARAM=/silent IGNORE_FAILURE=YES PATCHES=
[FaroSDK] PRODUCT_NAME=FaroSDK EXE_PATH=..\support\FaroSDK\faro_ls.msi LOG=%tmp%\FaroSDK.log ACTION=INSTALL EXE_PARAM= PATCHES=
[MSXML] PLATFORM=NATIVE PRODUCT_NAME=MSXML 6 EXE_PATH=..\support\msxml\msxml6.msi EXE64_PATH=..\support\msxml\msxml6_x64.msi VC_FUNC=MsxmlVerCheck VC_PARAM=6.0 VC_SOURCE=SetupUi.dll IGNORE_FAILURE=YES DISK_LABEL=C3D2011_64_Bit DISK_PROMPT=AeccSetupRes.dll;50 EXE_PARAM= PATCHES=
[WMF] PLATFORM=x64 PRODUCT_NAME=Windows Media Format 9.5 EXE64_PATH=support\WMF\wmfdist64.exe EXE_PARAM=/quiet IGNORE_FAILURE=YES VC_FUNC=WMFCheck VC_PARAM=9.5 VC_SOURCE=SetupUi.dll PATCHES=
[VCREDIST2005X64] PLATFORM=x64 PRODUCT_NAME=Microsoft Visual C++ 2005 Redistributable (x64) EXE64_PATH=support\VCRedist\2005\vcredist_x64.exe EXE_PARAM=/q:a /T:%windir%\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v %temp%\vcredist_x64_2005.log"" " VC_FUNC=VCx64RedisCheck VC_PARAM={071C9B48-7C32-4621-A0AC-3F809523288F} VC_SOURCE=SetupUi.dll PATCHES=
[VCREDIST2005X86] PLATFORM=ALL PRODUCT_NAME=Microsoft Visual C++ 2005 Redistributable (x86) EXE_PATH=support\VCRedist\2005\vcredist_x86.exe EXE_PARAM=/q:a /T:%windir%\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v %temp%\vcredist_x86_2005.log"" " VC_FUNC=VCx86RedisCheck VC_PARAM={7299052B-02A4-4627-81F2-1818DA5D550D} VC_SOURCE=SetupUi.dll PATCHES=
[VCREDISTX64] PLATFORM=x64 PRODUCT_NAME=Microsoft Visual C++ 2008 Redistributable (x64) EXE64_PATH=support\VCRedist\2008\x64\install.exe EXE_PARAM=/q /l %temp%\vcredist_x64_2008.log VC_FUNC=VCx64RedisCheck VC_PARAM={4B6C7001-C7D6-3710-913E-5BC23FCE91E6} VC_SOURCE=SetupUi.dll PATCHES=
[VCREDISTX86] PLATFORM=ALL PRODUCT_NAME=Microsoft Visual C++ 2008 Redistributable (x86) EXE_PATH=support\VCRedist\2008\x86\install.exe EXE_PARAM=/q /l %temp%\vcredist_x86_2008.log VC_FUNC=VCx86RedisCheck VC_PARAM={1F1C2DFC-2D24-3E06-BCB8-725134ADF989} VC_SOURCE=SetupUi.dll PATCHES=
[NLSDL] PLATFORM=NATIVE PRODUCT_NAME=Microsoft NLS Downlevel APIs EXE_PATH=NLSDL\nlsdl.x86.exe EXE64_PATH=NLSDL\nlsdl.amd64.exe EXE_PARAM=/quiet /norestart DISKCOST=200000 IGNORE_FAILURE=YES
[VBPOWERPACK] PLATFORM=ALL PRODUCT_NAME=Microsoft Visual Basic Power Packs 3.0 EXE_PATH=support\VBPowerPacks\VisualBasicPowerPacks3Setup.exe EXE_PARAM=/q /l %tmp%\VisualBasicPowerPacks3Setup.log IGNORE_FAILURE=YES PATCHES=
[SQL_CE_x86] PLATFORM=ALL PRODUCT_NAME=SQL Server CE 3.5 x86 EXE_PATH=en-US\Support\SQL_Server_CE_3.5\x86\SSCERuntime-ENU-x86.msi IGNORE_FAILURE=YES DISK_LABEL=C3D2011_64_Bit DISK_PROMPT=AeccSetupRes.dll;50 EXE_PARAM= PATCHES=
[SQL_CE_x64] PLATFORM=X64 PRODUCT_NAME=SQL Server CE 3.5 x64 EXE64_PATH=en-US\Support\SQL_Server_CE_3.5\x64\SSCERuntime-ENU-x64.msi IGNORE_FAILURE=YES DISK_LABEL=C3D2011_64_Bit DISK_PROMPT=AeccSetupRes.dll;50
#==================== LanguagePack C3D Postrequisite EXE_PARAM= PATCHES= [C3D_LANGPACK] PRODUCT_NAME=AutoCAD Civil 3D Language Pack EXE_PATH=%lang%\C3D\AcadLP.msi EXE64_PATH=%lang%\C3D\AcadLP.msi ADMIN_INSTALL=YES LOG=%tmp%\C3D LangPack Install.log
#==================== C3D [C3D] PLATFORM=NATIVE PREREQUISITE=OS;SSE2;DOTNET;DOTNETUPDATE;VCREDIST2005X86;VCREDIST2005X64;VCREDISTX86;VCREDISTX64;DIRECTX;FaroSDK;MSXML;WMF;CM;CMILL;ADR;VBPOWERPACK;SQL_CE_X86;SQL_CE_X64;IE POSTREQUISITE= PRODUCT_NAME=AutoCAD Civil 3D 2011 PRODUCT_ICON=C3D\c3d.ico EULA_PATH=eula LOG=%tmp%\AutoCAD Civil 3D 2011 Install.log EXE_PATH=C3D\C3D.msi EXE64_PATH=C3D\C3D.msi EXE_PARAM= ACTION=INSTALL REMOVE_PATH= ROLLBACKABLE=YES USE_EXTERNAL_UI=YES USE_MEDIA=YES UI_SEQUENCE=LicenseTypePage;InstallTypePage;ContentPackPage;ConfigFolderPage;ServicePackPageForDeploy;ServicePackPageForInstall;InfoCenterCommCenterPage;OnlineResourcesPage;ConfigCompletePage MAINTENANCE_UI_SEQUENCE=MaintenanceDlg;AddRemoveFeaturesDlg;ContentPackDlg;RepairDlg;MaintVerifyReadyDlg;FullProgressDlg;MaintCompleteDlg;MaintFailedDlg EXTRA_FEATURES=Express_Tools SUMMARY_FUNC=LoadSummary_ACAD SUMMARY_SOURCE=AecSetup.dll README_FILE=help\readme.chm;AeccSetupRes.dll;30 LAUNCH_EXE=acad.exe ADMIN_INSTALL=YES EXTRA_FILES=acad;C3D\*.ico DEPLOYMENTLANGUAGE= CANSPAN=1
LPMODE=MLD AVAILABLELANGUAGES=en-us DEFAULTMEDIALANGUAGE=en-US
#==================== C3D UI Sequence EULA_INDEX=-1 EULA_STATE=YES CONFIG_TRANSFORM=C3D-2011C3D64b.mst STOCK_TRANSFORMS= TRANSFORMS= PATCHES=C3D\c3d2011_x64_sp1.msp
[LicenseTypePage] UI_CREATOR=LicenseTypePage UI_SOURCE=SetupAcadUi.dll UI_INFO_LINK=SetupRes\InfoLink\License_Type_%s.xml.html
[InstallTypePage] UI_CREATOR=InstallTypePage UI_SOURCE=SetupAcadUi.dll UI_INFO_LINK=SetupRes\InfoLink\Installation_Type_Page_ACAD.xml.html
[ContentPackPage] UI_CREATOR=ContentPackPage UI_SOURCE=AecSetup.dll UI_INFO_LINK=SetupRes\InfoLink\Content_Pack_Page.xml.html
[ConfigFolderPage] UI_CREATOR=ConfigFolderPage UI_SOURCE=AecSetup.dll UI_INFO_LINK=SetupRes\InfoLink\Configurable_Folder_Page.xml.html
[ContentPackDlg] UI_CREATOR=ContentPackDialog UI_SOURCE=AecSetup.dll UI_CONDITION=NOT REINSTALL="ALL" AND NOT REMOVE="ALL" UI_INFO_LINK=SetupRes\InfoLink\Content_Pack_PageDlg.xml.html
#==================== C3D Deploy UI Sequence
[ContentLocationPage] UI_CREATOR=ContentLocationPage UI_SOURCE=SetupAcadUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" UI_INFO_LINK=SetupRes\InfoLink\Support_Content_Page_ACAD.xml.html
[PathCustomizationPage] UI_CREATOR=PathCustomizationPage UI_SOURCE=DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" UI_INFO_LINK=SetupRes\InfoLink\Deployment_Define_Search_Paths_and_File_Locations_page.xml.html
[AddAdditionalFilesPage] UI_CREATOR=AddAdditionalFilesPage UI_SOURCE=DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" UI_INFO_LINK=SetupRes\InfoLink\Additional_Files_Page.xml.html
[WorkstationSettingPage] UI_CREATOR=WorkstationSettingPage UI_SOURCE=DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" UI_INFO_LINK=SetupRes\InfoLink\Specify_Users_Workstation_Settings_Page.xml.html
[ServicePackPageForDeploy] UI_CREATOR=ServicePackPage UI_SOURCE=DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" UI_INFO_LINK=SetupRes\InfoLink\Deployment_Include_Service_Packs_Page.xml.html
[ServicePackPageForInstall] UI_CREATOR=ServicePackPage UI_SOURCE=DeployUi.dll UI_CONDITION=ADSK_RUNNING_FROM_ADMIN="FALSE" AND NOT ADSK_LAUNCH_MODE="DEPLOYMENT" UI_INFO_LINK=SetupRes\InfoLink\Standalone_Include_Service_Packs_Page.xml.html
[InfoCenterCommCenterPage] UI_CREATOR=InfoCenterCommCenterPage UI_SOURCE=DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" UI_INFO_LINK=SetupRes\InfoLink\Deployment_Configure_InfoCenter_Communication_Center_Page.xml.html
[OnlineResourcesPage] UI_CREATOR=OnlineResourcesPage UI_SOURCE=DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" UI_INFO_LINK=SetupRes\InfoLink\Deployment_Online_Resources_Page.xml.html
[ConfigCompletePage] UI_CREATOR=ConfigCompletePage UI_SOURCE=SetupAcadUi.dll ~UI_INFO_LINK=SetupRes\InfoLink\Deployment_Configure_Complete_Page.xml.html
#==================== ADR
[ADR] PRODUCT_NAME=Autodesk Design Review 2011 (English) PREREQUISITE=SSE2;VCREDIST2005X86;VCREDISTX86;DOTNET;IE PRODUCT_ICON=%lang%\support\adr\DesignReview.ico EXTRA_FILES=acad;%lang%\support\adr\*.ico EULA_PATH=eula PRODUCT_MESSAGE=AeccSetupRes.dll;20 LOG=%tmp%\Autodesk Design Review Install.log EXE_PATH=%lang%\support\adr\SetupDesignReview2011.msi IGNORE_FAILURE=YES UI_SEQUENCE=InstallTypePage3;ConfigCompletePage MAINTENANCE_UI_SEQUENCE=MaintenanceDlg;AddRemoveFeaturesDlg;RepairDlg;MaintVerifyReadyDlg;FullProgressDlg;MaintCompleteDlg;MaintFailedDlg SUMMARY_FUNC=LoadSummary_Simple SUMMARY_SOURCE=SetupAcadUi.dll ALLOW_ADD_REMOVE=NO VC_FUNC=DwfvVerCheck VC_SOURCE=SetupUi.dll VC_PARAM=6.0 VC_DESCRIPTION=Detecting DWFViewer 7.0 earlier README_FILE=%platform%\%lang%\support\adr\README.htm;AcSetupRes.dll;106 DISK_LABEL=C3D2011_64_Bit DISK_PROMPT=AeccSetupRes.dll;50
LPMODE=MLD_ADR AVAILABLELANGUAGES=en-us DEFAULTMEDIALANGUAGE=en-US POSTREQUISITE= EXE_PARAM= EULA_INDEX=-1 EULA_STATE=YES ACTION=INSTALL CONFIG_TRANSFORM=SetupDesignReview2011-2011C3D64b.mst STOCK_TRANSFORMS= TRANSFORMS= PATCHES=
[InstallTypePage3] UI_CREATOR=InstallTypePage UI_SOURCE=SetupAcadUi.dll UI_INFO_LINK=SetupRes\InfoLink\Installation_Type_Page_DWFV.xml.html
#==================== CM : Autodesk ProMaterial 2011 Library
[CMSP1] PRODUCT_NAME=Autodesk Material Library 2011 Update 1 PLATFORM=ALL EXE_PATH=..\support\ADSKMaterials\CM\ProteinMaterialsSP1.msp ADMIN_INSTALL=NO PATCHES=
[CM] PRODUCT_NAME=Autodesk Material Library 2011 PLATFORM=ALL POSTREQUISITE=CMSP1 EXE_PATH=..\support\ADSKMaterials\CM\ProteinMaterials.msi LOG=%tmp%\MaterialLibrary2011CM.log ACTION=INSTALL
#==================== IL : Autodesk ProMaterial 2011 Library - Low Image Library EXE_PARAM= PATCHES= [CMILL] PRODUCT_NAME=Autodesk Material Library 2011 - Low Resolution PLATFORM=ALL EXE_PATH=..\support\ADSKMaterials\ILL\BaseImageLibrary.msi LOG=%tmp%\MaterialLibrary2011CMILL.log ACTION=INSTALL
#==================== Supplement Tools EXE_PARAM= PATCHES=
[NLM] PRODUCT_NAME=Network License Manager PRODUCT_GROUP=Network License Components PRODUCT_ICON=%lang%\support\NLM\NLM.ico EULA_PATH=eula LOG=%tmp%\NLM Install.log EXE_PATH=%lang%\support\NLM\NLM.msi INSTALL_TYPE=4 ACTION=INSTALL IGNORE_FAILURE=YES UI_SEQUENCE=InstallTypePage2;ConfigCompletePage SUMMARY_FUNC=LoadSummary_Simple SUMMARY_SOURCE=SetupAcadUi.dll ALLOW_ADD_REMOVE=NO DISK_LABEL=C3D2011_64_Bit DISK_PROMPT=AeccSetupRes.dll;50
LPMODE=MLD_ADR AVAILABLELANGUAGES=en-US DEFAULTMEDIALANGUAGE=en-US
[InstallTypePage2] UI_CREATOR=InstallTypePage UI_SOURCE=SetupAcadUi.dll UI_INFO_LINK=SetupRes\InfoLink\Installation_Type_Page_Tools.xml.html
[CADM] PRODUCT_NAME=Autodesk CAD Manager Tools 4.0 PRODUCT_GROUP=Supplemental Tools PRODUCT_ICON=%lang%\support\CADManager\CADManager.ico PREREQUISITE=SSE2 EULA_PATH=eula LOG=%tmp%\CADManager Install.log EXE_PATH=%lang%\support\CADManager\CADManager.msi INSTALL_TYPE=4 ACTION=INSTALL IGNORE_FAILURE=YES UI_SEQUENCE=InstallTypePage2;ConfigCompletePage SUMMARY_FUNC=LoadSummary_Simple SUMMARY_SOURCE=SetupAcadUi.dll ALLOW_ADD_REMOVE=NO DISK_LABEL=C3D2011_64_Bit DISK_PROMPT=AeccSetupRes.dll;50
[AAL] PRODUCT_NAME=Autodesk Asset Locator PRODUCT_GROUP=Supplemental Tools PRODUCT_ICON=%lang%\support\AAL\adpm_adpm.ico EULA_PATH=eula LOG=%tmp%\Autodesk Asset Locator.log EXE_PATH=%lang%\support\AAL\AAL.msi INSTALL_TYPE=4 ACTION=INSTALL IGNORE_FAILURE=YES UI_SEQUENCE=InstallTypePage2;ConfigCompletePage SUMMARY_FUNC=LoadSummary_Simple SUMMARY_SOURCE=SetupAcadUi.dll ALLOW_ADD_REMOVE=NO DISK_LABEL=acadHammer DISK_PROMPT=AcSetupRes.dll;11
[SAMR] PREREQUISITE=JRE PRODUCT_NAME=SAMreport-Lite PRODUCT_GROUP=Supplemental Tools PRODUCT_MESSAGE=SetupRes.dll;378 LOG=%tmp%\SAMreport.log EXE_PATH=..\support\SAMreport-Lite\SAMreport.exe EXE_PARAM=-is:javahome "%ProgramFiles%\Java\j2re1.4.2_04" VC_FUNC=SAMreportLiteCheck VC_SOURCE=SetupUi.dll INSTALL_TYPE=4 ACTION=INSTALL IGNORE_FAILURE=YES
[JRE] PRODUCT_NAME=JRE 1.4.2 EXE_PATH=..\support\SAMreport-Lite\Java 2 Runtime Environment, SE v1.4.2_04.msi EXE_PARAM= IGNORE_FAILURE=YES DISK_LABEL=C3D2011_64_Bit DISK_PROMPT=AeccSetupRes.dll;50
[CIVIL_OE] PRODUCT_NAME=Civil 3D 2011 Object Enabler PRODUCT_GROUP=Supplemental Tools PRODUCT_MESSAGE= LOG=%tmp%\Civil3D2011_OE.log EXE_PATH=support\ObjectEnabler\Civil3D_2011_OE_64Bit.exe INSTALL_TYPE=4 ACTION=INSTALL IGNORE_FAILURE=YES #=================VAULT_SUPPORT=====================
#[OS_EDM] #PRODUCT_NAME=Windows #PRODUCT_MESSAGE=EdmuiRes.dll;123 #VC_FUNC=EDMOsVerCheck #VC_SOURCE=EDMUi.dll #VC_DESCRIPTION=Detecting Windows #ACTION=INSTALL #EXE_PATH=NULL
#==================== DWG TrueView [DWGTRUEVIEW] PREREQUISITE=OS;IE;VCREDISTX64;VCREDISTX86;DOTNET;MSXML;WMF PRODUCT_NAME=DWG TrueView 2011 PLATFORM=NATIVE LOG=%temp%\DWG TrueView 2011 install.log EXE_PATH=support\DWGViewer\DWGVIEWR.msi EXE64_PATH=support\DWGViewer\DWGVIEWR.msi IGNORE_FAILURE=YES USE_EXTERNAL_UI=YES DISKCOST=250000000 ACTION=INSTALL DISK_LABEL=C3D2011_64_Bit DISK_PROMPT=AeccSetupRes.dll;50 EXE_PARAM= PATCHES=
[WSE30] PRODUCT_NAME=Microsoft WSE 3.0 Runtime EXE_PATH=support\WSE30\Microsoft WSE 3.0 Runtime.msi LOG=%temp%\edm_wse30.log VC_FUNC=CheckWSE3 VC_PARAM=3.0.5305.0 VC_SOURCE=EdmUi.dll ACTION=INSTALL DISK_LABEL=C3D2011_64_Bit DISK_PROMPT=AeccSetupRes.dll;50 EXE_PARAM= PATCHES=
[REPORTVIEWER] PLATFORM=ALL PRODUCT_NAME=Microsoft Report Viewer Redistributable 2008 EXE_PATH=support\ReportViewer\install.exe EXE_PARAM=/q /l %tmp%\edm_ReportViewer.log VC_FUNC=CheckReportViewer VC_PARAM={5E152D08-572A-3375-8FDE-DAD1EFB379BA} VC_SOURCE=EdmUi.dll ACTION=INSTALL DISK_LABEL=C3D2011_64_Bit DISK_PROMPT=AeccSetupRes.dll;50 #====================  Vault 2011 PATCHES= [VAULT_LANGPACK] PLATFORM=NATIVE PRODUCT_NAME=Autodesk Vault 2011 Language Pack EXE_PATH=%lang%\Client\VaultLP.msi EXE64_PATH=%lang%\Client\VaultLP.msi EXE_PARAM=SETUP=1 ADMIN_INSTALL=YES ROLLBACKABLE=NO DISK_LABEL=C3D2011_64_Bit DISK_PROMPT=AeccSetupRes.dll;50
[VAULT_en-US] LOG=%tmp%\Autodesk Vault 2011 English Language Pack Install.log ACTION=INSTALL DISK_LABEL=C3D2011_64_Bit DISK_PROMPT=AeccSetupRes.dll;50
#====  if qualified products are also selected to be installed, they should execute a function before CheckForProductSelection #====  to set property COMBINED_INSTALLER to their product section name in setup.ini #====  for example if Inventor combined with Vault, they should write a function: #====  INT_PTR APIENTRY DisableCombineCheck(UiContext* pUiContext) #====  { #====       CProduct* pProduct = NULL; #====       CSetupManager& setupManager = pUiContext->m_setupManager; #====       pProduct = setupManager.FindProduct(_T("VAULT")); #====       if (pProduct != NULL && !setupManager.IsDeploymentCreation() && pProduct->IsInstall()) #====       { #====        pProduct->SetMsiProperty(L"COMBINED_INSTALLER", L"INVENTOR"); #====       } #====       return IDOK; #====   } #====   in setup.ini: #====   [ProductSelectionDlg] #====   UI_FINALIZE_SOURCE=InventorUi.dll;edmUI.dll #====   UI_FINALIZE=DisableCombineCheck;CheckForProductSelection #====   if multiple qualified products are combined together, use ; as the delimeter PATCHES= [VAULT] VC_FUNC=ClientSideBySideCheck VC_SOURCE=EdmUi.dll PREREQUISITE=VCREDISTX64;VCREDISTX86;DOTNET;MSXML;WSE30;DIRECTX;ADR;WMF;DWGTRUEVIEW;REPORTVIEWER;IE PRODUCT_NAME=Autodesk Vault 2011 PRODUCT_ICON=Client\Program Files\Autodesk\Vault 2011\Setup\SetupRes\vault.ico PRODUCT_MESSAGE=EdmUIRes.dll;151 LOG=%tmp%\Autodesk Vault 2011 Install.log PLATFORM=NATIVE EXE_PATH=Client\Vault.msi EXE64_PATH=Client\Vault.msi EXE_PARAM=SETUP=1 REBOOT=ReallySuppress ACTION=INSTALL REMOVE_PATH= ROLLBACKABLE=NO USE_EXTERNAL_UI=YES UI_SEQUENCE=InstallTypePage_Vault;ServicePackPage_EDM;ConfigCompletePage MAINTENANCE_UI_SEQUENCE=MaintenanceDlg_EDM;AddRemoveFeaturesDlg_EDM;RepairDlg;VaultMaintVerifyReadyDlg;FullProgressDlg;MaintCompleteDlg;MaintFailedDlg SUMMARY_FUNC=LoadSummary_Client SUMMARY_SOURCE=edmUI.dll README_FILE=Readme_Vault.html;EdmUIRes.dll;135 LAUNCH_EXE= EULA_PATH=EULA ADMIN_INSTALL=YES EXTRA_FILES= LPMODE=MLD_INV AVAILABLELANGUAGES=en-us DEFAULTMEDIALANGUAGE=en-US DISK_LABEL=C3D2011_64_Bit DISK_PROMPT=AeccSetupRes.dll;50
#==================== Used to hide feature of vault POSTREQUISITE= EULA_INDEX=-1 EULA_STATE=YES CONFIG_TRANSFORM=Vault-2011C3D64b.mst STOCK_TRANSFORMS= TRANSFORMS= PATCHES= [InstallTypePage_Vault] UI_CREATOR=InstallTypePage UI_SOURCE=SetupAcadUi.dll UI_FINALIZE_SOURCE=EdmUI.dll UI_FINALIZE=CheckFeatureSelection UI_INFO_LINK=SetupRes\InfoLink\EDM_Vault_Configuration_Tab.xml.html [ServicePackPage_EDM] UI_CREATOR=ServicePackPage UI_SOURCE=DeployUi.dll UI_CONDITION=ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT" UI_INFO_LINK=SetupRes\InfoLink\EDM_Deployment_Include_Service_Packs_Page.xml.html [C3D_en-us] PATCHES= [C3D_SP0] PATCHES=
hashim.mundol
Yes, no tweaking required.
This is part of the admin image created, License server,Serial number details are in the deploymentname.mst file, INI file is mostly for the install sequence ,pre-requisites and to point to the right MSI/MST files.
If you need multiple image to point to the multiple servers, you can do this by modifying the existing one and saving with a new name along with license server changes. this will create new .INI,.MST and shortcuts
Hashim Mundol
Autodesk, Inc.
TravisNave
Sometimes the easiest way to update the NLM is simply to stop the service and replace the (4) .exe files with the newest version.
I have posted this in my NLM link in my signature below.  Good luck!
Autodesk Forums:
Administrator Productivity
