Chuck,
What we have done in these situations is create the deployment images on the
server that will have the flex license. We them had them mirror that drive
and put on the other servers for deployment only. This cut out the bandwidth
problems that come with multi office installs. Once deployed to client we
removed the local mirrors and the clients now all point to the license
server in a single location. Hope this helps.
Mike Gauvin
CADsoft Consulting - Arizona
mike.gauvin@cadsoft-consulting.com
"Chuck Blackford"
wrote in message news:41333abd$1_2@newsprd01...
> Question,
> If you are running multiple offices from the same flex license server, is
> it
> possible to have one client installation image that you use in multiple
> office. it appears that the ".MST" file has several server specific UNC
> paths. Has anyone had any luck editing these paths and using the same
> image
> from office to office, or do you have to spool a seperate image for each
> office's install?
> Thanks in advance for any feedback.
> Chuck
