For the benefit of the group:
It appears this problem is being caused by McAfee Virus scanner. When
On-Acess Scan is disabled, we do not have this problem. I am going to try
and figure out exactly what setting in the virus scanner is causing the
AutoCAD Installer to fail for subsequent users after the initial install.
If anyone has any ideas, I'd sure appreciate it.
"Chuck Blackford"
wrote in message news:41260b0c$1_2@newsprd01...
> We've had a reoccurring problem with our Network installation image of ADT
> 2005. It works fine when the first user logs into it and we load the
default
> "AutoCAD" profile which redirects some of the "Files" paths to the server.
> It works fine for the first user. However, every subsequent user on that
> machine, will get the "Menu Load Failed" upon start-up. In most cases, it
> appears to be looking for the menu in the users Documents and Settings
> folder. Then, if you attempt to reload the very same profile, that worked
> for the first user, you get the menu load error. The only option is to
> uninstall and reinstall the program. Then it works for the first user
again,
> but none of the subsequent users. I've seen similar posts for AutoCAD
2004,
> and a dll that was released for that version... but nothing for 2005.
Does
> anyone have any suggestions or know what I might be doing wrong?
> I appreciate any suggestions.
> Chuck
