Yes, here also, the network deployment went without a hitch. Now I'm looking
for an easy way to set up all the support drives and such. LT doesn't do
profiles, how else do you make sure everyone's install is set up the same
without going around to each machine and doing it manually?
"Matt Dwyer" wrote in message
news:7AE008A96DA0FC001D4FE88EA1357415@in.WebX.maYIadrTaRb...
> My server is a Win2K server with Active Directory.
> I just followed the instructions and it worked as advertised. Mind you, I
> have only set up 2 wkstations so far, so not well tested yet.
> fwiw
> >>> Chris Sos 06/13/2003 2:20:47
> PM >>>
> Hi,
> Does anyone know how to automate the installation of LT 2004 on a Windows
> 2000 Active Directory network? I've read some documentation that was
> pretty
> critical of 2002's ability to remotely install, but was hoping for
> improvement in 2004.
> I would greatly appreciate it if anyone had any experience or has heard of
> how this can be done. Best yet - is there a spot on Autodesk.com that
> documents the procedure?
> Many Thanks,
> Chris
> Matt Dwyer
> Dwyer Engineering
