Installation & Licensing
Need help for SAMreport
3 REPLIES 3
mirza.hamzic
546 Views, 3 Replies
Hello
I have a problem with SAMreport: I have tried to license it, but unsuccesfully. I suppose, it will not work properly (full) without licensing. When starting it, I got a message: Your application was not able to license because the FLEXnet license server manager could not determine where to find the licensing data it needs. Please choose one the following:
* Specify the license server System
* Specify the license file
I have tried both options, no result - still unlicensed.
When try to generate, message appears:
No input file(s) specified for this report.
Report generator NOT started.  See Status History.
Question: What is proper input file?
Product Installation Information:
SAMreport v3.6[UNLICENSED]
Home: C:\Program Files (x86)\Macrovision\samreport\v3.6
Machine: Windows Server 2008 x86 6.0
Java home: C:\Program Files (x86)\Java\jre1.6.0_18
Java version: 1.6.0_18
Java vendor: Sun Microsystems Inc.
__________________________
3 REPLIES 3
mirza.hamzic
in reply to: mirza.hamzic
I am opening SAM Report physically on the server (recommended) - still unlicensed.
mirza.hamzic
First step succesful: SAMreport licensed.
I try to generate report, but not able to do it, still.
TravisNave
Your license needs to be created for the same machine as the NLM server exists.  It needs to match it.  Then you need to point to the report log .rl file that you created with your options file.  You need to give this file time to actually record data first as well.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
