Installation & Licensing
Need To Deploy Trial Version of AutoCAD 2014
4 REPLIES 4
dj_xest
3053 Views, 4 Replies
Hello There,
I need to create an administrative image for a trial version of AutoCAD 2014 and having problems with the license key during the configuration.is there a way to skip this or a trial key to use?
For the moment, they are planning to use it for 30 days or until they have managed to acquire a budget for it and then users will then activate the product for themselves.
I could not find a way to do this. Someone from Autdesk enlighten me please. Thanks.
DJ
4 REPLIES 4
avto
in reply to: dj_xest
Hi DJ, I personally have never done a trial deployment for ACAD 2014, but I think if you just type some number (e.g. 123-45678901) in the Serial number box and use ACAD 2014 default product key 001F1, you should be able to create the deployment. Regards,
Avto Chachava
Autodesk Product Support
Autodesk, Inc.
dj_xest
in reply to: avto
The key that you have provided worked like a charm! I hope someone else might also use this solution. Thanks a bunch!
avto
You are very welcome DJ.
I'm glad to to know that my suggestion worked for you.
Avto Chachava
Autodesk, Inc.
lucifer_abhi
which installation cmd did you use?
Tags (1)
Administrator Productivity
