• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    *Quebbeman, Douglas H.
    Need Help with License Manager Bug w/Windows 2000 Professional
    71 Views, 3 Replies
    08-20-2000 07:00 AM
    Help!
    We are ADLM to license our seats over our LAN using TCP/IP, and on the
    workstations that have now upgraded to Windows 2000 Professional, we are
    getting the error message about not being able to reach the license server.
    I've downloaded the updated ADESKSYS.DLL, but the instructions say not to
    install it if the datetime stamp of the original isn't as per spec. Our
    existing
    ADESKSYS.DLL doesn't meet the spec; I tried the updated version anyway,
    and Autocad just hangs up on the splash screen.
    What can I do?
    Thanks in advance for all suggestions,
    -doug quebbeman
    systems administrator
    the estopinal group
    Please use plain text.
    Re: Need Help with License Manager Bug w/Windows 2000 Professional
    08-21-2000 08:03 AM in reply to: *Quebbeman, Douglas H.
    "Douglas H. Quebbeman" wrote in message
    news:23D64096DC7147B2117DB431C12A7E3B@in.WebX.SaUCah8kaAW...
    > Help!
    server.
    existing
    Ok, I have been able to solve my own problem by reading the thread
    "More ADT2 Win 2k network problems" by setting the environment
    variable ACADSERVER to @MYSERVERNAME (where MYSERVERNAME
    is the name of the server where ADLM is running). Either it was not required
    to set this variable previously, or, the preconfigured install was setting
    it for
    installations on NT machines but not for installations on Win2k machines.
    When I preconfigured the network install, I probably entered the server
    name in lower case; however, I notice Win2k is upper-casing lots of names
    that were formerly shown in all lower case.
    I am most disturbed that no one at Autodesk has updated the instructions
    contained in the text file pointed to by the link:
    ftp://ftp-2.autodesk.com/pub/autocad2000/patches/sys_dll.txt
    to include trying the environment variable fix first.
    Thanks to the participants in the "More ADT2 Win 2k network problems"
    thread for having thought sufficiently out loud to provide me with a clue.
    regards,
    -doug quebbeman
    the estopinal group
    *milana, jerry
    Re:
    08-21-2000 09:50 AM in reply to: *Quebbeman, Douglas H.
    Doug,
    The @ symbol issue is a requirement of the AEC products only, that is why it
    is not mentioned in the document you quote below, which applies to AutoCAD.
    There is a document in the pipeline for AEC products that explain this fix.
    Jerry Milana,
    Autodesk Product Support
    news:51F501C94C94905A145B30D0BAE5F74B@in.WebX.SaUCah8kaAW...
    message
    > > Help!
    > server.
    to
    > existing
    required
    > it for
    > regards,
    > -doug quebbeman
    > the estopinal group
    *Bulk, Frank
    Re:
    09-28-2000 02:42 PM in reply to: *Quebbeman, Douglas H.
    You saved my life! I was sure this couldn't be resolved, but this @
    symbol did the trick!
    Frank Bulk
    > > Help!
    > server.
    > existing
    > it for
    > regards,
    > -doug quebbeman
    > the estopinal group
    Frank Bulk (bulkf@dordt.edu)
