• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Durst, Connie
    Need Expert Advice - File Save Prob
    116 Views, 2 Replies
    11-08-1999 12:35 PM
    Need Expert Advice
    Our office is caught with a serious Autocad problem. There are many
    factors involved so it is hard to pin down just what the problem is.
    Perhaps someone has experienced this before.
    This is not happening to everyone. There are a few people who are having
    this problem repeatedly, but not all the time. The people who are having
    problems tend to be on the same teams. We have 2 or 3 projects which are
    continually having the problem while the others are usually fine.
    What's happening is that a file will be opened but does not close when
    the user exits out. So, he can then not save it. It tells him that
    someone else has the file open. We have the program "Who Has It" and can
    see many files open which really are not. Most of the time it is the
    user himself who the computer thinks has the file open. If the user logs
    off the computer the files are closed.
    Sometimes the files save without a problem. But when it does save, it is
    making multiple .bak files. It is naming them savxxxx.bak where xxxx is
    a random number. When the file cannot be saved it creates an ac$ temp
    file.
    Some of our users are running Win95, some Win98. All of them are running
    Autocad 14.01 Build version P.033c. The c patch is supposed to deal with
    this file not closing problem but I loaded that this weekend and the
    problem is still happening today.
    We are also running Netware 4.11 Service Pack 7. SP7 is also supposed to
    deal with a problem of files not being closed. There is an additional
    patch called Rev... something which I have also loaded on the server,
    but to no avail. Everyone is running Client 32 ver 3.1 SP2.
    This problem started when I first loaded SP1 on a few computers. I was
    able to remove SP1 at that time and everything went back to normal. It
    was after that that I loaded SP7 on the server and hoped that would
    solve the problem. I then loaded the client service packs hoping that
    would solve the problem. But, now I have tried removing Client 3.1 from
    one computer and the problem continued to happen. At this point everyone
    is forced to have to log off the network every time they want to get out
    of a file.
    Another factor that is probably not relevant is that two of the people
    who have this problem most and who actually seemed to have started it
    have just previously gotten Dell Pentium III 450 mhz machines. I am
    clutching at straws.
    Would anyone vote for unloading Client 32 3.1 from all computers and
    Service Pack 7 from the server? Or is it an Autocad problem?
    Please use plain text.
    *Milana, Jerry
    Re: Need Expert Advice - File Save Prob
    11-08-1999 01:47 PM in reply to: *Durst, Connie
    Connie,
    The patch you applied helps with read only problems associated with some
    Unix server connectivity products, as documented with the patch
    distribution. The read only problems with Netware servers is not addressed
    in this patch. If you still have this problem after installing Novell's
    latest client software, I suggest that you report the problem to Novell. If
    you are using the Netware AdLM to control licenses, you are stuck with using
    Novell's Client software. If you are running standalone licenses for
    AutoCAD or are using a Windows system to run the TCP/IP version of AdLM, you
    may want to try the Microsoft Client for Netware which is shipped with your
    Operating System.
    Jerry Milana,
    Autodesk Product Support
    Connie Durst wrote:
    > Need Expert Advice
    > file.
    > of a file.
    *Schmidt, John
    Re:
    11-08-1999 02:59 PM in reply to: *Durst, Connie
    Jerry,
    Connie's problem seems to be similar to the one I reported
    that MMWD was having. I talked to them today, and of all
    things, they said that if they set their isavepercent to
    100, (!!!????), the problem goes away. 'Makes no sense to
    me, but it's working for them, and they're happy with it...
    John
