i have a problem running Navisworks Simulate 2013 installation from deployment. When the install gets to 2013 DWG File Reader the installation of it fails and the whole installation rolls back.
If I install manually just the 2013 DWG File Reader the installation succeeds
msiexec /I "ODBX2013.msi"
I have to deploy this to hundreds of workstations so doing it manually is not an option for us.
A excerpt of the log file
Navisworks Simulate 2013 install error - 2013 DWG File Reader doesn't install
_______
Action start 11:24:48: NoInstallTargetsFound.
MSI (s) (10:AC) [11:24:48:931]: Product: Autodesk Navisworks Simulate 2013 - 2013 DWG File Reader -- No install products found
Action ended 11:24:48: NoInstallTargetsFound. Return value 3.
Action ended 11:24:48: INSTALL. Return value 3.
Property(S): NAVSIM_INSTALLED_VERSION = 10.0.840.82
Property(S): ProgramFiles64Folder = C:\Program Files\
Property(S): Manufacturer = Autodesk
Property(S): ProductCode = {CBED6FC7-FB20-4920-AA80-3D6F3459F902}
Property(S): ProductLanguage = 1033
Property(S): ProductName = Autodesk Navisworks Simulate 2013 - 2013 DWG File Reader
Solved by FT398. Go to Solution.
I've experienced similar problems - do you happen to have added a service pack into the deployment? I found that in my instance, the deployment rolled back because the installer expects to find certain file versions when installing the DWG readers but the versions are different due to them being patched by the service pack.
In the end we had to make a new deployment with no SP included and then add the SP to each machine after the initial install - not the slickest deployment method I've encountered.
OK thanks for the answer, I think you are spot on.
Yes, I did add the sp (it has usually worked...)
I test with a "clean" install...
Regards
Juha
As an additional bit of info on this matter, I updated our deployments today and decided to revisit the SP issue. I recall that the first time I built the image, I used the 'append' method for the SP where the SP is applied after the install of the original product. This time around I used the 'merge' method where the SP is applied to the actual original install and surprisingly this way it worked for me. It therefore looks that it is only the 'append' method that causes the failure - or at least this was the case in my situation.
