Installation & Licensing
NVIDIA Quadro 4000 and AutoCAD/C3D 2014?
2 REPLIES 2
TDenson
1224 Views, 2 Replies
Is the NVIDIA Quadro 4000 going to be certified for AutoCAD/C3D 2014? That card is not showing up on any of the 2014 Lists.
Tags (2)
2 REPLIES 2
TravisNave
in reply to: TDenson
Don't get too hung up on the lists.  Autodesk isn't going to certify every card.  I always lead with the disclaimer that a card that has a WHQL certified driver, is certified.
You can get a WHQL certified driver for this card on nVidia.com and you'll be just fine with AutoCAD 2014.  I have a few machines left in my enterprise that run this card without issues.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
dgorsman
in reply to: TravisNave
Its a little overkill for basic AutoCAD work, unless you are also using ReCap or other software that is heavily dependant on OpenGL.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Administrator Productivity
