• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Wheat, Chuck
    NT server disappeared
    88 Views, 9 Replies
    12-18-1999 12:06 PM
    Hello -
    The network consists of an NT4.0 server and Win95 clients, running tcp/ip.
    We successfully installed the adlm and deployment location on the server and
    got A2K running on the clients.
    Then we installed additional licenses in the adlm for ADT2 and a deployment
    location for ADT2.
    Since then, the clients don't see the server in Network Neighborhood
    anymore, although they do find A2K licenses after a long delay.
    How can we get the clients to see the server again? We'll be tackling this
    Monday morning -- maybe I don't need to bother autodesk support if some of
    you have suggestions!
    Chuck - cwheat233@yahoo.com - Denver, Colorado, USA
    Please use plain text.
    *Wheat, Chuck
    Re: NT server disappeared
    12-20-1999 02:37 PM in reply to: *Wheat, Chuck
    The server reappeared on the network after sitting idle over the weekend (go
    figure), so we were able to install ADT2 to the clients from the deployment
    location on the server. But only some of the clients can run ADT2. Most
    hang up when loading the aec stuff. That's probably when it tries to grab
    an ADT license, so I still think it has something to do with the adlm.
    No networking people in autodesk support have responded yet, so we are still
    hurting here.
    *Nehls, Kevin
    Re:
    12-20-1999 03:42 PM in reply to: *Wheat, Chuck
    That makes some sense. I don't know how big your network is, or if your IT
    department was doing something to your servers over the weekend. NT
    assigns 1 (and only 1) computer on the network as the Master Browser. This
    computer is responsible for maintaining the Browse list (the list you see
    in Network Neighborhood). This "replication" is very slow and can take up
    to 53 minutes. If the computer that maintains the Browse list was down,
    then you would not have seen any computer in Network Neighborhood that was
    not logged onto the network before it was taken down.
    Just a thought.
    Kevin Nehls
    for reply remove -ns-
    Chuck Wheat wrote in article
    <83mbes$ie310@adesknews2.autodesk.com>...
    (go
    deployment
    grab
    still
    > hurting here.
    *Wheat, Chuck
    Re:
    12-20-1999 05:36 PM in reply to: *Wheat, Chuck
    Well, the server with the adlm and the deployment location was only down
    very briefly when we restarted it once or twice. But something along the
    lines of what you described must have happened.
    Anyway the real problem now is the fact that most clients can't run ADT2,
    apparently because they can't grab licenses, while others do run it. It
    would be nice if this problem also healed itself after a couple of days of
    inactivity!
    *Nehls, Kevin
    Re:
    12-21-1999 08:12 AM in reply to: *Wheat, Chuck
    That it would, that it would. Can the clients that are not able to run
    ADT2 see the server now as well? Is your problem machine specific, or can
    you recreate it on any machine even the ones that are able to run ADT2?
    Kevin Nehls
    Chuck Wheat wrote:
    > It would be nice if this problem also healed itself after a couple of
    days of
    > inactivity! (snip)
    *Wheat, Chuck
    Re:
    12-21-1999 11:59 AM in reply to: *Wheat, Chuck
    All the clients see the server now and all can run A2K (well, there's one
    strange exception, but never mind!). When they try to run ADT2, they work
    initially in a new drawing (or one with no aec content). At that point,
    they have grabbed a product code 150 license but not a code 151 (ADT)
    license. As soon as you run an ADT-specific command, though, most of
    clients will hang. Only a couple manage to grab an ADT license and run.
    The clients are all identical new Gateway 450MHz Pentium III machines. It
    seems like the problem is machine-specific, even though the machines are
    essentially identical!
    Oh, maybe you could answer a second question, more of an NT issue. On the
    server, there are several redundant installations of autocad run trees and
    deployment locations. I can't delete them, even though I'm logged in as
    Administrator. I get a vague error message saying that maybe I don't have
    rights or maybe the files are in use. Any idea what I need to do to delete
    these?
    *Nehls, Kevin
    Re:
    12-21-1999 01:15 PM in reply to: *Wheat, Chuck
    What versions of acad are installed on the server? And were the
    installations installed on the server or were they copied there? Do you
    get the same message if you go through the control panel and use the
    add/remove programs applet?
    Kevin Nehls
    <83omia$mo431@adesknews2.autodesk.com>...
    the
    and
    have
    delete
    > these?
    *Wheat, Chuck
    Re:
    12-21-1999 05:28 PM in reply to: *Wheat, Chuck
    When installing network autocad on a server, you only get an entry in the
    control panel uninstall list if you choose the server install option. The
    client install basically just copies files onto the server, creating a
    deployment location. I made three installations (not counting the adlm):
    client a2k, server a2k and client adt2. So the current server a2k
    installation is the only one that shows up in the uninstall list, and I
    don't want to uninstall it. The other folders that I would like to delete
    are either old client deployment locations or maybe the remains of old
    server installation run trees. Thus, the uninstall list is correct and does
    not reference anything that I want to delete now.
    The installations I made were done from the cd, not copied from somewhere.
    I'm pretty sure that's true of the older ones that I want to erase, too.
    *Wheat, Chuck
    12-29-1999 05:29 PM in reply to: *Wheat, Chuck
    Just so it's clear, in case someone at Autodesk reads this next week -
    The current problem is that ADT2 fails to grab a license when it needs it.
    In a new drawing, ADT2 runs up until the time an actual ADT command is
    invoked, having grabbed an A2K license at the beginning. As soon as it
    needs the ADT2 license, ADT2 hangs. On a network with about 20 clients, 2
    or three machines can successfully run ADT2 and the rest have this problem.
    The machines are identical, new Gateway 450MHz Pentium III's.
    Any suggestions will be appreciated.
    *Schroeder, Bud
    Re:
    12-30-1999 10:42 PM in reply to: *Wheat, Chuck
    Hi Chuck,
    I'm not sure what exactly is going on here, but you could write a resource file
    to hold your ADT 2 license files.
    Hope this helps.
    Bud
