• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    .NET4 Problems Installing DWGTrueView2013_64bit
    632 Views, 2 Replies
    03-28-2012 12:10 AM
    Hi does anyone have a solution for the problem i encounter?
    My Computer is running on Windows Vista Home Premium (64 bit) and i have an issue installing the programme SetupDWGTrueView2013_64bit.
    After downloading the file from: http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=9078813
    after unzipping the file and intialising the programmme for installation, the error message saying that .Net4 is not installed. Contact the system adminstrator for more information.
    I have the latest version of .Net4 from the microsoft website and the same problem occurs.
    Any solutions?
    Please use plain text.
    Product Support
    Re: .NET4 Problems Installing DWGTrueView2013_64bit
    03-30-2012 07:15 AM in reply to: samuelcbk
    Hi samuelcbk;
       I could be that there's simply a problem with the .NET installation. Have you tried repairing it and running the Windows updates again to see if it helps?
    Dwayne
    Dwayne Poot
    Support Specialist
    Product Support
    Autodesk, Inc.
    *Expert Elite*
    TravisNave
    03-30-2012 09:02 AM in reply to: samuelcbk
    You need to install the full version of .NET 4 on the machine.  Most basic installations of .NET only include a partial upgrade install.
    Also consider this update:
    http://support.microsoft.com/kb/2468871
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
