Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
.NET Framework Cleanup Tool for Unhandled Exception Errors
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Problem: You launch your Autodesk product and receive an unhandled exception error similar to this error:
Unhandled e0434f4dh exception at 7c81eb33h
This problem is caused by .NET Framework not being installed properly, or another problematic issue within the .NET Framework system.
Solution: Most often, this can be resolved by reinstalling the appropriate .NET Framework prerequisite for your release. Instructions can be found here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
However in many cases, it may be necessary to remove the .NET Framework installations completely with the use of the .NET Framework Cleanup Tool.
This .NET Framework cleanup tool is designed to automatically perform a set of steps to remove selected versions of the .NET Framework from a computer. It will remove files, directories, registry keys and values and Windows Installer product registration information for the .NET Framework. The tool is intended primarily to return your system to a known (relatively clean) state in case you are encountering .NET Framework installation, uninstallation, repair or patching errors so that you can try to install again.
Before using this tool to remove any version of the .NET Framework from your system, please note:
• This tool is designed as a last resort for cases where install, uninstall, repair or patch installation did not succeed for unusual reasons. It is not a substitute for the standard uninstall procedure.
• This cleanup tool will delete shared files and registry keys used by other versions of the .NET Framework. If you run the cleanup tool, you will need to perform a repair/re-install for all other versions of the .NET Framework that are on your computer or they will not work correctly afterwards.
The .NET Framework cleanup tool supports removing the following products:
•.NET Framework - All Versions
•.NET Framework 1.0
•.NET Framework 1.1
•.NET Framework 2.0
•.NET Framework 3.0
•.NET Framework 3.5
•.NET Framework 4
When choosing to remove any of the above versions of the .NET Framework, the cleanup tool will also remove any associated hotfixes and service packs. You do not need to run any separate steps to remove the service pack(s) for a version of the .NET Framework.
Once your .NET Framework installations have been all cleared, you will need to reboot and then reinstall the latest .NET Framework prerequisites for your products. You can find these installations on your Autodesk media or by downloading them from Microsoft at http://www.microsoft.com/net/
I am attaching the .NET Framework Cleanup Tool here for your convenience.
Good Luck!
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Solved! Go to Solution.
Re: .NET Framework Cleanup Tool for Unhandled Exception Errors
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
At the time of this post, the latest version of the .NET Cleanup Tool includes .NET Framework 4.0 and was released on January 17, 2011.
You can always find the latest version of this tool here:
http://cid-27e6a35d1a492af7.skydrive.live.com/self
Help Improve the Autodesk Discussion Groups
If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems. Please add Kudos to a post if you were helped by a post that you did not author.
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: .NET Framework Cleanup Tool for Unhandled Exception Errors
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I actually tried this. I ran this, it cleaned up the files. I tried to install again, got the same error. Then I went to reinstall the files and got that error again! I hope I didn't mess anything else up by runing that clean up on my machine.
Back to (0,0) again. ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Does your Control Panel > Programs show that .NET Framework is installed?
You can always System Restore back to before you ran the utility.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You know, it doesn't even show its installed. But when I try to install it, it won't. Yes - system restore, will do now.
Any other thoughts?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Check to see if Windows Update will do it. If your system came pre-installed with .NET 4.5 (like Win8 does) then you might be able to get around this by modifying your setup.ini file to exclude the prereq check for it. If not, then you're gonna have a hard time getting this to work.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'd followed the .net cleanup tool, reinstalled .net Framwork V4 and now I'm up and running, really appreciated your help.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi man. I'm having this problem with .NET Framework in Windows8. How can I modify the setup.ini file to exclude the prereq check?
Cheers!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
