Installation & Licensing
Member
Ottodinda
Message 1 of 6 (837 Views)
My Inventor 2013 cant Run after Installation
837 Views, 5 Replies
09-16-2012 07:33 PM
I have a problem with my inventor, why after  inventor installed it won't be open. Like autocancel in the middle of loading, but last time i have successfully open it and run it. Then suddenly it can't open anymore. I have already block antivirus and use CCleaner or Tuneup, but that still doesn't work. Help please. Some one
Product Support
david.lau
Message 2 of 6 (807 Views)
Re: My Inventor 2013 cant Run after Installation
09-17-2012 11:53 AM in reply to: Ottodinda
I would uninstall the software, reboot and re-install it. Any registry cleaner can potentially remove important files.  You can also try to create a new user account with Admin privileges to see if it can run in that account.
David Lau
Member
Ottodinda
Message 3 of 6 (785 Views)
09-17-2012 11:59 PM in reply to: Ottodinda
I try already to make new user and install inventor 2013...The Inventor Professional 2013 still doesn't run... But the other programs such as Fusion 2013,Vaultbasic 2013,Design Review 2013 are working. My system Requirements are compatible, even Net 4.0 is there. Need more Advice, thanks.
n.k.timofeev
Message 4 of 6 (730 Views)
10-21-2012 05:05 PM in reply to: Ottodinda
I have a similar error. You can find my question here:  http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2013-Crashes-Instantly/td-p/3636986
I reinstalled and tryed pretty much everything to remove Inventor 2013. Now when I instal Inventor 2013 and it's components, the computer thinks that I already have it (probbaly due to saved licence) but all other components get installed and run fine.
I am still looking for a solution.
Product Support
dembkod
Message 5 of 6 (702 Views)
10-23-2012 02:38 PM in reply to: Ottodinda
This could be a few things, I suppose. Possibly a corrupt Inventor User Profile.
Rename the following folders:
C:\Users\<<YOUR USER>>\AppData\Local\Autodesk\Inventor 2013
C:\Users\<<YOUR USER>>\AppData\Roaming\Autodesk\Inventor 2013
You can also rename your TSF file. It will resemble this: ADSKFLEX_NUMBERS_TSF.data. It should be located here:
Settings\All Users\Application Data\FLEXnet
Vista/Windows 7:
C:\ProgramData\FLEXnet
Rename this file. Then try to Start Inventor.
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
n.k.timofeev
Message 6 of 6 (692 Views)
10-23-2012 06:56 PM in reply to: Ottodinda
This solved the problem:
THANK YOU AUTODESK SUPPORT!
Dear Nikita Timofeev,
Thank you for contacting Autodesk.
We sincerely apologize for any inconvenience you may have experienced with your Inventor 2013. To double check the uninstallation status of your Inventor 2013, we kindly invite you to visit the pages below to go thru the recommended solutions or procedures from there:
Uninstalling Inventor:
http://usa.autodesk.com/getdoc/id=TS14893355
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
