Installation & Licensing
Mutliple versions of Civil 3D on a single computer : installation and use
2 REPLIES 2
Vincent_Fredon
184 Views, 2 Replies
Is it possible to install and to work with different versions of Civil 3D on a computer ?
I try to install civil 3D 2010 on a computer where Civil 3D 2012 is alreaydy instaled.
But the installation fails and returns this message :
Thanks for your help.
Vincent Fredon
2 REPLIES 2
TravisNave
in reply to: Vincent_Fredon
Yes but you should probably install them in order.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Vincent_Fredon
in reply to: TravisNave
Thanks.
I will try an installation on a virtual machine to keep my Civil 2012.
Vincent Fredon
Administrator Productivity
