Installation & Licensing
Member
jmcrosenbaum
Message 1 of 6 (202 Views)
Multiple license servers/one computer?
202 Views, 5 Replies
08-13-2013 01:14 PM
I am wondering if it's possible to run 2 versions of C3d from separate license servers on one single computer?
Thanks in advance,
jr
TravisNave
Message 2 of 6 (195 Views)
Re: Multiple license servers/one computer?
08-13-2013 01:44 PM in reply to: jmcrosenbaum
Welcome to the community.
To answer your question... most likely.  But to be clear, what exactly are you trying to accomplish?
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
jmcrosenbaum
Message 3 of 6 (190 Views)
08-13-2013 03:52 PM in reply to: TravisNave
Working for 2 separate companies, so using only A's network license for A's projects and B's network license for B's projects. I would like to install both on one workstation so when I travel (and doing work for both), I'm not dragging 2 workstations along for the ride.
TravisNave
Message 4 of 6 (162 Views)
08-14-2013 07:34 AM in reply to: jmcrosenbaum
I see what you mean.  You can only borrow two licenses for one product under the following circumstances:
1.  You login with a different user account and borrow the licenses as different users
2.  You borrow a license from one server using the hard-wired Ethernet NIC on one server and the your WiFi card on the second server
In either of these situations, you will have a borrowed license from each server for one application.
Ultimately, it does not matter whose license you use though.  The software doesn't really care.
Member
jmcrosenbaum
Message 5 of 6 (158 Views)
08-14-2013 08:19 AM in reply to: TravisNave
Many many thanks for your reply!
Is the connection dedicated? In other words, if I am only using one license, will it default to the WiFi connection, or is the method of connection dedicated (where A always uses the Ethernet NIC connection when B is not using the WiFi connection)? (sorry, I know the software pretty well, but the IT end of things...not my thing, at all).
TravisNave
Message 6 of 6 (154 Views)
08-14-2013 08:34 AM in reply to: jmcrosenbaum
Right.
The borrowed license is tied to the username and the network card.  So if you borrow a license with the NIC, then it needs to be enabled to work.  If you borrow a license with the WiFi, it needs to be enabled to work.  In both cases, if you disable one the other license will be used on the other card.
Likewise, if you login as User1, it will use one license. If you login with User2, it will use the other.
Either way would suffice in your situation.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
