Trying to deploy Infrastrucutre Design Suite 2012 on W7 and Vista 64 bit OS' with all windows updates including .net. I keep getting the same typical scenario; rollbacks with a 1603 error right about the time it hits the Medium Resolution Material Library. Log below. Thank you!
2011/10/26:12:42:13 davhaf CPU192 === Setup started on CPU192 by davhaf ===
2011/10/26:12:42:13 davhaf CPU192 Launch
2011/10/26:12:43:37 davhaf CPU192 === Setup ended ===
2011/10/26:12:42:14 davhaf CPU192 === Setup started on CPU192 by davhaf ===
2011/10/26:12:42:14 davhaf CPU192 Launch
2011/10/26:12:43:37 davhaf CPU192 PageOpen LaunchDialog
2011/10/26:12:48:57 davhaf CPU192 PageOpen LicenseDialog
2011/10/26:12:49:04 davhaf CPU192 PageOpen ProductInfoDialog
2011/10/26:12:49:31 davhaf CPU192 PageOpen ProductSelectionDialog2
2011/10/26:12:49:41 davhaf CPU192 PageOpen FullProgressDialog
2011/10/26:12:49:41 davhaf CPU192 Installing DirectX Runtime: G:\3rdParty\DirectX\DXSETUP.exe /silent
2011/10/26:12:53:33 davhaf CPU192 Install DirectX Runtime Succeeded
2011/10/26:12:53:34 davhaf CPU192 Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/26:12:53:36 davhaf CPU192 Install FaroSDK Succeeded
2011/10/26:12:53:36 davhaf CPU192 Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/26:12:54:05 davhaf CPU192 Install Autodesk Material Library 2012 Succeeded
2011/10/26:12:54:06 davhaf CPU192 Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/26:12:54:37 davhaf CPU192 Install Autodesk Material Library 2012 - Low Resolution Succeeded
2011/10/26:12:54:37 davhaf CPU192 Installing Microsoft Visual C++ 2005 Redistributable (x86): G:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\davhaf\AppData\Local\Temp\vcredist_x86_2005.log"" "
2011/10/26:12:54:54 davhaf CPU192 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2011/10/26:12:54:55 davhaf CPU192 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/26:12:55:11 davhaf CPU192 Install Autodesk Content Service Succeeded
2011/10/26:12:55:11 davhaf CPU192 Installing SQL Server CE 3.5 x86: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/26:12:55:25 davhaf CPU192 Install SQL Server CE 3.5 x86 Succeeded
2011/10/26:12:55:25 davhaf CPU192 Installing SQL Server CE 3.5 x64: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/26:12:55:33 davhaf CPU192 Install SQL Server CE 3.5 x64 Succeeded
2011/10/26:12:55:33 davhaf CPU192 Installing Microsoft Visual Basic Power Packs 3.0: G:\3rdParty\VBPowerPacks\VisualBasicPowerPacks3Setup.exe /q /l C:\Users\davhaf\AppData\Local\Temp\VisualBasicPowerPacks3Setup.log
2011/10/26:12:55:43 davhaf CPU192 Install Microsoft Visual Basic Power Packs 3.0 Succeeded
2011/10/26:12:55:45 davhaf CPU192 Installing AutoCAD® Civil 3D® 2012: TRANSFORMS="G:\x64\en-us\C3D\C3D.mst;C:\Users\davhaf\AppData\Local\Temp\_AI760B.tmp\x64\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/26:13:06:14 davhaf CPU192 Install AutoCAD® Civil 3D® 2012 Succeeded
2011/10/26:13:06:17 davhaf CPU192 Installing AutoCAD® Civil 3D® 2012 Language Pack: TRANSFORMS="C:\Users\davhaf\AppData\Local\Temp\_AI760B.tmp\_la7492.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/26:13:11:03 davhaf CPU192 Install AutoCAD® Civil 3D® 2012 Language Pack Succeeded
2011/10/26:13:11:03 davhaf CPU192 Installing Microsoft Visual C++ 2005 Redistributable (x86): G:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\davhaf\AppData\Local\Temp\vcredist_x86_2005.log"" "
2011/10/26:13:11:41 davhaf CPU192 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2011/10/26:13:11:41 davhaf CPU192 Installing Microsoft Visual C++ 2005 Redistributable (x64): G:\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\davhaf\AppData\Local\Temp\vcredist_x64_2005.log"" "
2011/10/26:13:12:11 davhaf CPU192 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2011/10/26:13:12:11 davhaf CPU192 Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/26:13:29:02 davhaf CPU192 Install Autodesk Material Library 2012 - Medium Resolution Library Failed Installation aborted, Result=1603
2011/10/26:13:29:02 davhaf CPU192 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2011/10/26:13:29:02 davhaf CPU192 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2011/10/26:13:30:30 davhaf CPU192 Rollback AutoCAD® Civil 3D® 2012 Language Pack Succeeded
2011/10/26:13:32:49 davhaf CPU192 Rollback AutoCAD® Civil 3D® 2012 Succeeded Reboot is required
2011/10/26:13:32:49 davhaf CPU192 Rollback Microsoft Visual Basic Power Packs 3.0 Failed Failure is ignored, Result=1619
2011/10/26:13:32:52 davhaf CPU192 Rollback SQL Server CE 3.5 x64 Succeeded
2011/10/26:13:33:11 davhaf CPU192 Rollback SQL Server CE 3.5 x86 Succeeded
2011/10/26:13:33:20 davhaf CPU192 Rollback Autodesk Content Service Succeeded
2011/10/26:13:33:20 davhaf CPU192 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2011/10/26:13:33:50 davhaf CPU192 Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2011/10/26:13:34:37 davhaf CPU192 Rollback Autodesk Material Library 2012 Succeeded
2011/10/26:13:34:39 davhaf CPU192 Rollback FaroSDK Succeeded
2011/10/26:13:34:39 davhaf CPU192 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Can you check out the following post:
Those keys didn't exist in the Vista 64bit registtry I am having issues with. HEre is a dropbox link to log file:
http://dl.dropbox.com/u/4776527/AutoCAD%20Civil%203D%202012%20Install.log
