Installation & Licensing
Member
SonnyBone
Message 1 of 6 (1,759 Views)
Multiple 2010 64-bit Autodesk products crashing on startup
1759 Views, 5 Replies
08-08-2010 10:37 AM
I purchased the 2010 Entertainment Creation suite, and several programs are crashing at startup. All of the 32 bit versions of the programs start properly, and SOME of the 64 bit versions are working.
(all 2010 software)
Working
3D Studio Max 32 bit
3D Studio Max 64 bit
MatchMover 32 bit
MatchMover 64 bit
Maya 32 bit
Motion Builder 32 bit
Mudbox 32 bit
Toxik 32 bit
DirectConnect 32 bit
DirectConnect 64 bit
Not Working
Maya 64 bit
Motion Builder 64 bit
Mudbox 64 bit
Softimage 64 bit
Toxik 64 bit
System
Windows Vista 64-bit Home Premium SP2
Intel i7 920 @ 2.67GHz
9 GB RAM
NVIDIA GeForce GTX 260 (driver 8.17.12.5896)
I glanced at a log for Maya 64 bit and it just has this over and over:
info: pid:5936 tid:5700 21:05:36.982000 MC3 is starting up...
info: pid:5936 tid:5700 21:10:21.433000 MC3 is shutting down...
I've searched for help on this subject, but I can't seem to track down the problem. I'm very frustrated at this point because I have a system capable of running 64-bit software, yet I'm stuck using the 32-bit versions. I have the latest Windows updates, I've tried a clean re-install, and I've tried different display drivers, but nothing has helped. Any ideas? What other info do you need from me to help diagnose these problems?
Product Support
vivekramesh
Message 2 of 6 (1,728 Views)
Re: Multiple 2010 64-bit Autodesk products crashing on startup
08-10-2010 02:22 AM in reply to: SonnyBone
Have you submitted the Customer Error Report ? If so which email ID have you used?
If you can please attach the log file or the crash dump file for review
Vivek Ramesh
Product Support Specialist
Global Services
Member
SonnyBone
Message 3 of 6 (1,711 Views)
08-11-2010 05:23 PM in reply to: vivekramesh
I don't get an option so submit a report to Autodesk, only to Microsoft. I don't get to an Autodesk splash page or loading page at all.
I get THE MAYA APPLICATION FILE HAS STOPPED WORKING - WINDOWS IS CHECKING FOR A SOLUTION TO THIS PROBLEM before anything has a chance to appear on screen.
I searched my logs and the 64 bit Maya log is empty. All it says is:
Maya Message Log starting Sunday, August 08, 2010
However, there is a CER.INI file with this:
[2010 x64]
CrashCount=0
SessionStartCount=25
SessionCleanCloseCount=6
The Mudbox 64 bit log is attached, as it actually contains something.
Just to verify... I'm finding the individual logs in the program folders within My Documents. Is this correct?
Member
SonnyBone
Message 4 of 6 (1,573 Views)
10-16-2010 11:06 PM in reply to: SonnyBone
I just upgraded to Windows 7 and I'm still having the same problem.
I was able to catch a log from Motion Builder 2010 64 bit and will attach it to this post. There is a txt file and an XML file that seems rather valuable, as it actually has some appcrash info:
APPCRASH
motionbuilder.exe
10.0.0.0
4a64c26a
StackHash_871b
6.1.7600.16385
4a5be02b
c0000374
00000000000c6cd2
I've been waiting a long time to find some way to fix these errors, and it would be nice to hear something other than BUY THE 2011 SUITE. I have updated all my drivers to match the new OS, btw.
Member
SonnyBone
Message 5 of 6 (1,539 Views)
10-17-2010 11:58 PM in reply to: SonnyBone
I just uninstalled the entire 2010 suite and cleaned my registry of all Autodesk traces and attempted to install the 64 bit version of the Maya 2011 trial just for kicks.
Same problem.
Crashes before showing a Splash page.
Attaching error logs.
Member
SonnyBone
Message 6 of 6 (1,177 Views)
02-05-2011 09:48 AM in reply to: SonnyBone
I found the problem, and it has nothing to do with Autodesk or Windows all.
I own a Wacom Intuos 4 tablet and the driver was causing a conflict across multiple 64 bit apps. I discovered this when installing Adobe CS5. The solution was to uninstall the Wacom tablet and drivers, and then install an older driver (6.1.3-5) that does not cause this conflict.
I can now run 64 bit applications and use my tablet without any issues.
I hope this information proves to be useful to others with a similar problem.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
