In a multiseat installation, each workstation that AutoCAD is installed on must be activated. All a multiseat license says, is that for this one serial number, there are say 15 seats that can be activated. Versus with a regular standalone license, you have one serial number per seat.
The multiseat license was created to allow large companies to not have to keep track of which serial number was given to which employee.
A license can be 'borrowed' in a sense. In order to 'borrow' the license both computers have to be on the same network. The reason the 'borrowed' is in quotes is because with a multiseat license you are transferring rights from one machine to another on a permanent basis, at least for as long as the machine 'borrowing' the license stays alive. It won't be able to truly re-activate the license if say the OS was reinstalled.
In a network license situation, you can truly borrow. Meaning that a license can be checked out from the server, but instead of on a permanent basis, there is a maximum period of 30 days (can be shorter if situation requires this) and at the end of the borrow period the client is deactivated and the license is reactivated for use on the server.
Message was edited by: rwilkins
Ronnie Wilkins, Jr.
