Installation & Licensing
Mudbox runtime error please help
6 REPLIES 6
johnno60
4120 Views, 6 Replies
Dear sir
  After 3 weeks with the new mudbox 2011and have sculpture a few items and have a number of files saved, my last work day on the mudbox was interupted by a shut  down of the mudbox programme. A frame of text asked if I wished to save the work which I had no time to respond , and lost valuable work , the screen went white with a framed message shown on the screen, Quote
       Runtime error
This application has requested the runtime to terminate it in a unusal way
Please contact the application's support team for more information.
   I have tried to enter the mudbox several times since and am shown the same information and cannot enter the mudbox .
 Am running Window's 7 Home Premium64bit oem  1GB nVidia Quadro 600 PCI Express video card if this is any help.
John
6 REPLIES 6
david.lau
in reply to: johnno60
Try restting the Mudbox preferences.
Go to My Documents and rename "Mudbox" to "Mudbox old".  Then restart Mudbox.
David Lau
johnno60
Could this procedure be a little expanded to know which , my documents folder I should enter, the one on mudbox or the computer desk top.  Where do I go from there ????   Please explain every step in detail please ,  Does restart mudbox mean to enter into mudbox or does it mean to reload the software into the computer again ???? If I alter some file in the My documents section how is this going to alter the mudbox programme so this problem doesen't happen again.??
Johnno
david.lau
Here is a screen shot to help you out.
David Lau
raik_zaika
in reply to: david.lau
Thanks a lot!!! I had the same problem and I solved it because of your suggestion 🙂
tonbb
Hello.
I did the reset of the mudbox folder as you sugested and renamed it to mudbox old and the runtime error did disapear as you told it would.
However, Now, a few weeks later, the runtime error is back again.
Any other ideas?
richardxom
OMG.. you saved my life.. literally !!!
Administrator Productivity
