I just downloaded and installed the Mac OSX version of Mudbox 2011, and now when I open the application, I get
any solutions?
Solved by david.lau. Go to Solution.
Mudbox is a very demanding application. Please check out:
http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=16391880
That site was specificly for mudbox 2012, which is not what I am running.
I have a GMA 950 graphics card, which is why I assume the program is not compatable, even though I have Maya 2011 and it runs perfect. Is there a work around to let me use mudbox? Or is there another program I could use with my GMA 950 card which is similar to Mudbox?
Thanks.
For all versions, go here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=14960418&linkID=11937426
The Intel Graphics Media Accelerator is not supported. In fact, Mudbox and Showcase are the only 2 products that I know for sure that will not install in a virtual environment. The video card requirements are "massive". There is no workaround for this issue.
So basically unless I get a better video card, Mudbox or anything like Mudbox is a no-go? Darn, I guess I will stick to Maya for as long as possible.
