Installation & Licensing
Moving my cad from one computer to another
1 REPLY 1
asherjoh
440 Views, 1 Reply
I have AUTOCAD 2010. It is on a outdated computer that I am going to toss. It is a stand alone disk or 1 station, not sure of the difference. Is there any problem with me unistalling cad on the old computer and installing it on the new computer?
1 REPLY 1
TravisNave
in reply to: asherjoh
Welcome to the community.
There shouldn't be any problem with you canning the old system and reinstalling it on the new one.  However, keep in mind the following:
1.  If you ever upgraded this license either manually or under Subscription, then it is expired because 2010 has been retired as of release 2014.  Install the latest version you own in this case.
2.  If you try to use the LTU to move the license, then it might have a 13-month expiry date due to the above reason.
If this is your latest license that has never been upgraded, then you should be able to activate it normally on the new machine over the Internet.  I would just try doing so.  If it fails, you can probably get an activation code for it, manually.
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
