Installation & Licensing
Moving Standalone ACAD 2009 License to New Workstation ...
3 REPLIES 3
267 Views, 3 Replies
Well the title pretty much says it all. We have a standalone ACAD 2009 license that need to be moved to a new workstation that is replacing the old one. Is there a special procedure for this or can we just expect a normal install? Just trying to reduce downtime while not violating my license agreement.
Any help is appreciated. Thanks.
- Curt -
3 REPLIES 3
TravisNave
Curt,
You should be able to easily install and activate your product on your other workstation. If you have problems, call the Autodesk Activations Hotline at 1-800-551-1490 and they will be able to get you an activation code.
Good luck!
Autodesk Forums:
Thank you Travis. After I posted this I did some more reading and thought I might use the Portable License Utility. But your way sounds even easier.
Take care.
- Curt -
TravisNave
Yeah, I wouldn't even bother with the PLU. It is more trouble than it is worth. That's why I didn't even mention it. 😉
Autodesk Forums:
Administrator Productivity
