Installation & Licensing
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Moving Network License Manager to different server
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
594 Views, 2 Replies
09-28-2011 07:50 AM
We are currently using the FLEXlm network license manager for AutoCAD 2005. We need to move the FLEXlm to a different server due to the obsolesence of the old server. Our subscription service is expired, but we kept it through the AutoCAD 2009 release. We never upgraded to AutoCAD 2009.
My questions are:
1) Can we move the FLEXlm to a different server and still receive a new AutoCAD 2005 authorization/lic file, even though our subscription has expired?
2) If we upgrade to AutoCAD 2009, can we then move the FLEXlm to a new server?
Thanks.
Re: Moving Network License Manager to different server
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-28-2011 09:10 AM in reply to:
jim.zahler
you have to generate a new license file for the new server
you need your serial number. server name, mac address
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-28-2011 09:32 AM in reply to:
jim.zahler
You will probably only be able to get a LIC file for your last available version, unless you can get an exception from Autodesk. You might consider upgrading to 2012 on Subscription so you don't have this problem in the future. Otherwise, you can keep that server on life support specifically to be your NLM server. Good luck!
Travis Nave
My Expert Contributions to the Discussion Groups:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
