I did this recently, copied all deployment folders and files from the old
machine to the new machine. But I also moved the nic card from the old
machine to the new machine and named the new machine the same as the old one
and changed the old machine name.
Phew, that was a mouthful! It worked very well for me.
Steve
"James Wedding" wrote in message
news:466BD45307867998D65961EEA7A65CA8@in.WebX.maYIadrTaRb...
> I think you'll have to create a new image. Sorry. I believe that there are
> some pointers in the Setup.exe that point to the UNC name of the
> installation server. I would try it, and if it runs, great!
> The other thing you'll have to do is search for the licpath.lic file in
one
> of your current installations. Edit this with Wordpad or some such to
point
> to the new server. You'll need to input the MAC address of the new server
in
> this file, so get it from the LMTools before you edit the file. When you
> have this, put it somewhere on the network.
> Assuming step one works, and the installation is OK, you'll want to copy
> this lic file over the one that gets installed by the Setup.exe program.
> That image points license requests to your old LM installation, this new
> file will point to the new LM installation.
> Hopefully, Jason or one of the adeskers will come tell me if I missed a
> step, but this should cover it I think.
> HTH-
> James Wedding, P.E.
> IT Manager
> Jones & Boyd, Inc.
> Dallas, TX
> jwedding@*NOSPAM*jones-boyd.com
