• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *T., Scott
    More info . .
    116 Views, 4 Replies
    01-15-2001 01:38 AM
    This is one of the entries in my ADLM log. It pertains to the user in with
    the problem:
    01-Jan-12 11:18:44: Bob@cad2 [0]: Authorization failure; key
    /adlm/key\250.lic only valid for: fga
    Please use plain text.
    *Support], Anthony Governanti [Autodesk
    Re: More info . .
    01-15-2001 04:57 AM in reply to: *T., Scott
    That suggests that only that user is allowed to have that license, you may
    have some access restriction implemented. Try logging in as admin on the
    machine to see if it releases the license.
    Anthony Governanti [Autodesk Support]
    AEC Product Support Americas
    WW Support & Services, Autodesk
    *T., Scott
    Re:
    01-15-2001 05:28 AM in reply to: *T., Scott
    I have, and it still doesn't work.
    "Anthony Governanti [Autodesk Support]"
    wrote in message
    news:18A77F2A9110E8836EC860B15F64BB67@in.WebX.SaUCah8kaAW...
    Re: More info . .
    01-15-2001 05:34 AM in reply to: *T., Scott
    Best thing to DO is Post in the Network News Group. Its hard for me to
    troubleshoot over email, with my limited experience in the ADLM. The
    Network NG will have more adept people there to answer you.
    *milana, jerry
    Re: More info . .
    01-16-2001 07:37 AM in reply to: *T., Scott
    If fga is the hostname of your server, then it means either something has
    changed in your network properties and has caused a server code change or
    your server has more than one network interface (physical or logical).
    In the former case, a new auth code(s) will do the trick. If it is the
    later, either remove all but one interface and reauthorize or move AdLM to
    another system.
    jerry milana,
    Autodesk Product Support
    "Scott T." wrote in message
    news:smileyvery-happy:F71A5F1D14E624B3778CA9A99FF1CDE@in.WebX.SaUCah8kaAW...
    with
    > the problem:
