Installation & Licensing
Monitoring all license usage from distributed license server set up
14 REPLIES 14
Message 1 of 15
avto
3075 Views, 14 Replies
Recently Autodesk Product Support was asked how to capture all license usage from distributed license server set up.
We would like to get a solution out to a larger audience of users through this post.
You need to install Autodesk License Server tools and then run the command below on a DOS shell from “C:\Program Files\Autodesk Network License Manager” folder, serverStat.txt file will capture the command output.
lmutil lmstat -a -c @License_server_1;@License_server_2;@License_server_3 > serverStat.txt
Avto Chachava
Autodesk, Inc.
14 REPLIES 14
Message 2 of 15
syitha
in reply to: avto
So our license server setup is as follows:
  1. We have 15 licenses of the Autocad/Revit Suite
  2. We have 5 licenses for just Autocad
  3. We have 2 Revit Structure licenses
  4. They are distributed among three servers:
  • Server 1 - 11AutoCAD/Revit, 1 Revit Structure, 5 AutoCAD
  • Server 2 - 2 AutoCAD/Revit, 1 Revit Structure
  • Server 3 - 2 AutoCAD/Revit
How does AutoCAD determine which license to use when the application is opened?
Does it depend on the serial number associated with the deployment?
Message 3 of 15
JTBWorld
in reply to: syitha
It is based on the order they are added and if the first does not have any license available the next one will be checked.
http://www.jtbworld.com/Autodesk-Network-License-Manager.htm#_Toc308431824
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 4 of 15
syitha
in reply to: JTBWorld
Thank you for the quick response.
Do you mind reviewing my License Status Enquiry?
I perused your link and I am very curious as to how you created that graph. Was it automated or manually done?
Message 5 of 15
JTBWorld
in reply to: syitha
What do you want reviewed in the status report?
What graph did you have in mind?
Jimmy Bergmark
Message 6 of 15
syitha
Apologies for the ambiguity.
I want you to review the status report to see if this would work correctly.
Some users are not able to open Autocad 2011 because the license server is saying there are no available licenses. In the status report we have 6 of 15 suite licenses that are not used, whereas the 5 autocad licenses are all taken up.
Do I have to rearrange some lines in the license file so that I can achieve proper license grabbing? This would mean if another user opened AutoCAD, would it grab the AutoCAD/Revit license?
For the graph, I want to basically see which licenses are used throughout the day. I believe your JTB Flexreport would do the job. This would enable us to actually see the real-world usage instead of assuming that every user is using AutoCAD or Revit 8 hours a day.
Your website is very detailed and will take some time to digest. Sorry for not reading before asking you these questions.
Message 7 of 15
JTBWorld
in reply to: syitha
For knowing for sure I need to see the license files (not a good idea to post them online so you can email them) and I also need to know how the products were installed, possibly the settings on the clients as described in the first link.
Yes JTB FlexReport can create these graphs/charts of the usage as well as in list format and HTML snapshot reports. Email me for a free trial.
Jimmy Bergmark
Message 8 of 15
DarrenP
its also a good idea to update your license manager you are running old ones
the latest one is 11.9 which is on the 2012 media
DarrenP
Message 9 of 15
JTBWorld
in reply to: DarrenP
Good catch Darren, having older versions can mess up things.
Jimmy Bergmark
Message 10 of 15
DarrenP
also another tip is to generate each combined license file on the same day
other wise it can cause problems with cascading
DarrenP
Message 11 of 15
JTBWorld
Creating them on the same day is only needed if you combine into one license file. Otherwise I'm not aware of any problem generating them on different days.
Jimmy Bergmark
Message 12 of 15
DarrenP
i am saying each servers license file when combined everything in that license would have to be generated on the same day
there are known issues with cascading with the 2012 products
DarrenP
Message 13 of 15
JTBWorld
Agree, and that's why it might be needed to review the license files to determine that. It can be done by searching for ISSUED= and then make sure the date is the same for all instances within the license file.
Jimmy Bergmark
Message 14 of 15
syitha
Mr. Bergmark,
I sent the license file via the textbox in private message since I do not have your email address. syi(at)timhaahs(dot)com is mine if you prefer to correspond in that way.
If you think it's a better idea for me to talk to someone at Autodesk, I can do that too.
Message 15 of 15
JTBWorld
in reply to: syitha
I got one attachment. Question is if this was for one license server or all. If it was for one license server your problem might be that the parts are issued at different dates. Suggestion then is to request a completely new license file for each server.
I've added link for contact details on my profile as well as sent you a direct email.
Jimmy Bergmark
Administrator Productivity
