Installation & Licensing
MoldFlow 2013 won't launch. "A security failure has occured"
0 REPLIES 0
Message 1 of 1
684 Views, 0 Replies
Hello
I tried installing a stand-alone version of MoldFlow 2013 on my laptop (no network server here).
It installed ok, but when I double click the icon to launch it, it gives me this error message:
A security failure has occured.  Check the following -
1.  You are using the correct license server.
2.  You are using an appropriate version of product security.
(The installation guide will specify the appropriate version of product security to use.)
3.  The license server has valid licenses installed.
4.  You can access the license server.
I am not using license server, so #1,3 and 4 do not apply (I think?)
I searched installation guide, and licensing guide, but no mention of what is the correct "version of product security to use."
I disabled my firewall and tried to launch the program.  Also did not work.
Strangely, Autodesk MoldFlow Simulation Communicator 2013 installed ok.  It will launch and appears to work properly.  Same with Inventor Fusion.
Can somebody please explain what I need to do to get Autodesk Simulation MoldFlow 2013 to run properly?
0 REPLIES 0
Administrator Productivity
