Installation & Licensing
Modbox2012 Reinstallation Problem
2 REPLIES 2
209 Views, 2 Replies
I am having problem with reinstalling Mudbox2012. After I
submit my serial # and product key, the program says that Mudbox is already
installed… Note: I did remove it before reinstalling.
Probably there is a file/s that I have to delete manually…
Can someone help? Thank you!!!
2 REPLIES 2
TravisNave
Installation problems may be resolved using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Please note that Windows Vista/7 users should try the clean uninstall method by Autodesk before attempting to use the MSICUU2.exe application.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Thank you, Travis, for your help!
I have tried it all but nothing worked... Still says, the Mudbox
is installed. Smiley Sad I did REGEDIT and nothing...
Are there Mudbox specific files that have to be deleted
manually?
Administrator Productivity
