I am having problem with reinstalling Mudbox2012. After I
submit my serial # and product key, the program says that Mudbox is already
installed… Note: I did remove it before reinstalling.
Probably there is a file/s that I have to delete manually…
Can someone help? Thank you!!!
Installation problems may be resolved using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Please note that Windows Vista/7 users should try the clean uninstall method by Autodesk before attempting to use the MSICUU2.exe application.
Thank you, Travis, for your help!
I have tried it all but nothing worked... Still says, the Mudbox
is installed. I did REGEDIT and nothing...
Are there Mudbox specific files that have to be deleted
manually?
