Installation & Licensing
New Member
SFForest
Message 1 of 4 (196 Views)
Accepted Solution
Missing link between Robot and Revit 2013
196 Views, 3 Replies
11-15-2013 04:59 AM
My company would like to investigate how Autodesk Robot works with Revit. I installed a trial version of Autodesk Robot 2012 but I'm not getting the Analysis & Code Check Options in Revit. Is that because it is a trial version or do I need to install something else? Thanks for your help.
Scott
*Expert Elite*
DarrenP
Message 2 of 4 (189 Views)
Re: Missing link between Robot and Revit 2013
11-15-2013 06:04 AM in reply to: SFForest
its a separate installation you get from subscription center
New Member
SFForest
Message 3 of 4 (183 Views)
11-15-2013 06:14 AM in reply to: DarrenP
The link between Robot 2012 works with Revit 2012 but not Revit 2013. Does the year associated with Robot need to match the Revit year? Is there a trial version of Robot 2013? Will Robot 2014 work with Revit 2013? Thanks again for the help,
Scott
*Expert Elite*
DarrenP
Message 4 of 4 (179 Views)
11-15-2013 06:26 AM in reply to: SFForest
they both have to be the same version
you can download 2013 from here:
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Please accept as a solution if this fully resolves the issue
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
