Installation & Licensing
Employee
alison.gangler
Message 11 of 43 (853 Views)
Re: Missing Assemblies on Tool Palette after network deployment of Civil 3D 2013
09-20-2012 09:47 AM in reply to: justforthispost
Thanks for confirming that the .cab files exist. In this case, the next step to determine the cause of the behavior is to examine the permissions which could possible be blocking the cabs from unpacking.
What is the OS of the system where the deployment AdminImage is hosted? Please verify that the account used to launch the install of the deployment has full Admin permissions, especially in the location of the deployment and across the OS of the server.
Also, you can elevate the Windows Installer policy by adding the following registry key on the client workstation and the server:
[HKEY_CURRENT_USER\Software\Policies\Microsoft\Windows\Installer]
"AlwaysInstallElevated"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\Installer]
There is additional information about this Windows Installer policy at:
http://msdn.microsoft.com/en-us/library/aa367561(v=vs.85).aspx
Microsoft recommends that the policy be set back to "0" upon completion of the install maintenance.
If you would prefer not to set this policy, please make sure that the UAC, User Account Control Settings are set to the lowest level so that the install sequences are not blocked by the security.
Please let me know if any of these suggestions help.
Cheers,
Alison
___________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Alison Gangler
IPG - ICP Install Engineer
Active Contributor
justforthispost
Message 12 of 43 (828 Views)
09-24-2012 12:31 AM in reply to: alison.gangler
As this installation is being done by group policy's the SYSTEM account is being used to install the application. This account has all the appropiate rights on the file locations and hasn't been "restricted" with UAC. It's not possible to login on a machine with this account as its a builtin Windows account. The deployment Adminimage is hosted on a Windows Server 2003 R2 x64 machine.
So for now I'm sorry to report that these suggestions don't help. I do not really understand why the installation works correctly when useing the .lnk file. What is the difference between that and assigning the MSI + MST files through GPO?
Active Contributor
justforthispost
Message 13 of 43 (786 Views)
10-01-2012 11:08 PM in reply to: justforthispost
Any update?
Active Contributor
justforthispost
Message 14 of 43 (759 Views)
10-08-2012 03:17 AM in reply to: alison.gangler
Hello guys, any update please?
Employee
alison.gangler
Message 15 of 43 (752 Views)
10-08-2012 08:45 AM in reply to: justforthispost
Thank you for the update and I'm sorry that the suggestions haven't helped so far. What account is being used to launch the install when you apply through the GPO?
Please keep in mind that if the System account is being used, this could cause the behavior you are seeing. In this case, can you try the local Admin account to launch the install? The Content Packs will install to the account user folders for the account used to launch the install.
Please let me know if this helps at all.
Cheers,
Alison
Alison Gangler
Active Contributor
justforthispost
Message 16 of 43 (719 Views)
10-11-2012 02:01 AM in reply to: alison.gangler
Thanks for your reply.
Can you please tell me how to set up my group policy so it will be run by a different account?
Active Contributor
justforthispost
Message 17 of 43 (683 Views)
10-23-2012 05:20 AM in reply to: justforthispost
Anyone?
Distinguished Contributor
ceethreedee.com
Message 18 of 43 (624 Views)
11-11-2012 08:55 PM in reply to: justforthispost
Resolution for this?
Did anyone have one. We have the smae problem here!
Regards
Brad
Civil 3D 2014 (SP2)
Win 7 Pro x64 -DELL Precision Workstation T3500
Intel Xeon 3.3GHz (w3680) -24Gb Ram
NVIDIA Quadro 2000 (1GB)
ceethreedee.com
ceethreedee.com
Message 19 of 43 (623 Views)
11-11-2012 08:58 PM in reply to: ceethreedee.com
From Cp log, there are heaps more where they came from though
!=> Failed to resolve Content\en\C3D_Imperial_Base\Profile.cab
!=> Failed to resolve Content\en\C3D_Metric_Base\Profile.cab
!=> Failed to resolve Content\en\C3D_ImageAssets\ImageAssets.cab
!=> Failed to resolve Content\en\C3D_ImageAssets\VideoTooltips.cab
!=> Failed to resolve Content\en\C3D_Profiles\ToolPalettes.cab
!=> Failed to resolve Content\en\C3D_Profiles\ToolCatalogs.cab
!=> Failed to resolve Content\en\C3D_Profiles\HHExpress.cab
!=> Failed to resolve Content\en\C3D_Profiles\HHHydrographs.cab
!=> Failed to resolve Content\en\C3D_Profiles\HHStormSewers.cab
!=> Failed to resolve Content\en\C3D_RoadCatalogs\Road_Catalogs.cab
!=> Failed to resolve Content\en\C3D_VizCatalogs\visualization.cab
!=> Failed to resolve Content\en\C3D_VizCatalogs\WS_Cat_Imperial.cab
!=> Failed to resolve Content\en\C3D_PPipesCat\PressurePipesCat.cab
!=> Failed to resolve Content\en\C3D_PPipesCat\PressurePipesConfig.cab
!=> Failed to resolve Content\en\C3D_PPipesCat\PartPublishingWizard.cab
!=> Failed to resolve Content\en\C3DCK_ANZ\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_ANZ\InstallDir.cab
!=> Failed to resolve Content\en\C3DCK_ANZ\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_ANZ\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_ANZ\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_Austria\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_Austria\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_Austria\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_Austria\InstallDir.cab
!=> Failed to resolve Content\en\C3DCK_Austria\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_Belgium\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_Belgium\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_Belgium\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_Belgium\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_Belgium\InstallDir.cab
!=> Failed to resolve Content\en\C3DCK_Brazil\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_Brazil\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_Brazil\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_Brazil\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_Brazil\InstallDir.cab
!=> Failed to resolve Content\en\C3DCK_Denmark\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_Denmark\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_Denmark\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_Denmark\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_Denmark\InstallDir.cab
!=> Failed to resolve Content\en\C3DCK_Germany\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_Germany\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_Germany\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_Germany\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_Germany\InstallDir.cab
!=> Failed to resolve Content\en\C3DCK_India\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_India\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_India\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_India\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_India\InstallDir.cab
!=> Failed to resolve Content\en\C3DCK_Italy\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_Italy\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_Italy\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_Italy\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_Italy\InstallDir.cab
!=> Failed to resolve Content\en\C3DCK_Mexico\InstallDir.cab
!=> Failed to resolve Content\en\C3DCK_Mexico\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_Mexico\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_Mexico\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_Mexico\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_Netherlands\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_Netherlands\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_Netherlands\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_Netherlands\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_Netherlands\InstallDir.cab
!=> Failed to resolve Content\en\C3DCK_Norway\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_Norway\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_Norway\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_Norway\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_Norway\InstallDir.cab
!=> Failed to resolve Content\en\C3DCK_Romania\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_Romania\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_Romania\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_Romania\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_Romania\InstallDir.cab
!=> Failed to resolve Content\en\C3DCK_SouthAfrica\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_SouthAfrica\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_SouthAfrica\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_SouthAfrica\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_Spain\InstallDir.cab
!=> Failed to resolve Content\en\C3DCK_Spain\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_Spain\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_Spain\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_Spain\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_Sweden\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_Sweden\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_Sweden\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_Sweden\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_Sweden\InstallDir.cab
!=> Failed to resolve Content\en\C3DCK_Switzerland\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_Switzerland\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_Switzerland\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_Switzerland\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_Switzerland\InstallDir.cab
!=> Failed to resolve Content\en\C3DCK_UKIE\AllUsers.cab
!=> Failed to resolve Content\en\C3DCK_UKIE\PerUser.cab
!=> Failed to resolve Content\en\C3DCK_UKIE\PerUser_Local.cab
!=> Failed to resolve Content\en\C3DCK_UKIE\DataDir.cab
!=> Failed to resolve Content\en\C3DCK_UKIE\InstallDir.cab
Civil 3D 2014 (SP2)
ceethreedee.com
Active Contributor
justforthispost
Message 20 of 43 (610 Views)
11-13-2012 04:15 AM in reply to: alison.gangler
We are still having this problem, so no resolution as yet.
