• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Product Support
    Re: Missing Assemblies on Tool Palette after network deployment of Civil 3D 2013
    09-20-2012 09:47 AM in reply to: justforthispost
    Thanks for confirming that the .cab files exist. In this case, the next step to determine the cause of the behavior is to examine the permissions which could possible be blocking the cabs from unpacking.
    What is the OS of the system where the deployment AdminImage is hosted? Please verify that the account used to launch the install of the deployment has full Admin permissions, especially in the location of the deployment and across the OS of the server.
    Also, you can elevate the Windows Installer policy by adding the following registry key on the client workstation and the server:
    [HKEY_CURRENT_USER\Software\Policies\Microsoft\Windows\Installer]
    "AlwaysInstallElevated"=dword:00000001
    [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\Installer]
    There is additional information about this Windows Installer policy at:
    http://msdn.microsoft.com/en-us/library/aa367561(v=vs.85).aspx
    Microsoft recommends that the policy be set back to "0" upon completion of the install maintenance.
    If you would prefer not to set this policy, please make sure that the UAC, User Account Control Settings are set to the lowest level so that the install sequences are not blocked by the security.
    Please let me know if any of these suggestions help.
    Cheers,
    Alison
    ___________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Alison Gangler
    Support Specialist
    Product Support
    Please use plain text.
    Active Contributor
    justforthispost
    09-24-2012 12:31 AM in reply to: alison.gangler
    As this installation is being done by group policy's the SYSTEM account is being used to install the application. This account has all the appropiate rights on the file locations and hasn't been "restricted" with UAC. It's not possible to login on a machine with this account as its a builtin Windows account. The deployment Adminimage is hosted on a Windows Server 2003 R2 x64 machine.
    So for now I'm sorry to report that these suggestions don't help. I do not really understand why the installation works correctly when useing the .lnk file. What is the difference between that and assigning the MSI + MST files through GPO?
    Active Contributor
    justforthispost
    10-01-2012 11:08 PM in reply to: justforthispost
    Any update?
    Active Contributor
    justforthispost
    10-08-2012 03:17 AM in reply to: alison.gangler
    Hello guys, any update please?
    Product Support
    10-08-2012 08:45 AM in reply to: justforthispost
    Thank you for the update and I'm sorry that the suggestions haven't helped so far. What account is being used to launch the install when you apply through the GPO?
    Please keep in mind that if the System account is being used, this could cause the behavior you are seeing. In this case, can you try the local Admin account to launch the install? The Content Packs will install to the account user folders for the account used to launch the install.
    Please let me know if this helps at all.
    Cheers,
    Alison
    Alison Gangler
    Support Specialist
    Product Support
    Active Contributor
    justforthispost
    10-11-2012 02:01 AM in reply to: alison.gangler
    Thanks for your reply.
    Can you please tell me how to set up my group policy so it will be run by a different account?
    Active Contributor
    justforthispost
    10-23-2012 05:20 AM in reply to: justforthispost
    Anyone?
    Active Contributor
    11-11-2012 08:55 PM in reply to: justforthispost
    Resolution for this?
    Did anyone have one. We have the smae problem here!
    Regards
    Brad
    Civil 3D 2013 (SP1)
    Win 7 Pro x64
    DELL Precision Workstation T3500
    Intel Xeon 3.3GHz (w3680)
    24Gb Ram
    NVIDIA Quadro 2000 (1GB)
    Active Contributor
    11-11-2012 08:58 PM in reply to: bkanthergolder
    From Cp log, there are heaps more where they came from though
    !=> Failed to resolve Content\en\C3D_Imperial_Base\Profile.cab
    !=> Failed to resolve Content\en\C3D_Metric_Base\Profile.cab
    !=> Failed to resolve Content\en\C3D_ImageAssets\ImageAssets.cab
    !=> Failed to resolve Content\en\C3D_ImageAssets\VideoTooltips.cab
    !=> Failed to resolve Content\en\C3D_Profiles\ToolPalettes.cab
    !=> Failed to resolve Content\en\C3D_Profiles\ToolCatalogs.cab
    !=> Failed to resolve Content\en\C3D_Profiles\HHExpress.cab
    !=> Failed to resolve Content\en\C3D_Profiles\HHHydrographs.cab
    !=> Failed to resolve Content\en\C3D_Profiles\HHStormSewers.cab
    !=> Failed to resolve Content\en\C3D_RoadCatalogs\Road_Catalogs.cab
    !=> Failed to resolve Content\en\C3D_VizCatalogs\visualization.cab
    !=> Failed to resolve Content\en\C3D_VizCatalogs\WS_Cat_Imperial.cab
    !=> Failed to resolve Content\en\C3D_PPipesCat\PressurePipesCat.cab
    !=> Failed to resolve Content\en\C3D_PPipesCat\PressurePipesConfig.cab
    !=> Failed to resolve Content\en\C3D_PPipesCat\PartPublishingWizard.cab
    !=> Failed to resolve Content\en\C3DCK_ANZ\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_ANZ\InstallDir.cab
    !=> Failed to resolve Content\en\C3DCK_ANZ\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_ANZ\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_ANZ\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_Austria\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_Austria\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_Austria\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_Austria\InstallDir.cab
    !=> Failed to resolve Content\en\C3DCK_Austria\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_Belgium\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_Belgium\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_Belgium\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_Belgium\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_Belgium\InstallDir.cab
    !=> Failed to resolve Content\en\C3DCK_Brazil\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_Brazil\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_Brazil\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_Brazil\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_Brazil\InstallDir.cab
    !=> Failed to resolve Content\en\C3DCK_Denmark\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_Denmark\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_Denmark\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_Denmark\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_Denmark\InstallDir.cab
    !=> Failed to resolve Content\en\C3DCK_Germany\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_Germany\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_Germany\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_Germany\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_Germany\InstallDir.cab
    !=> Failed to resolve Content\en\C3DCK_India\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_India\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_India\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_India\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_India\InstallDir.cab
    !=> Failed to resolve Content\en\C3DCK_Italy\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_Italy\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_Italy\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_Italy\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_Italy\InstallDir.cab
    !=> Failed to resolve Content\en\C3DCK_Mexico\InstallDir.cab
    !=> Failed to resolve Content\en\C3DCK_Mexico\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_Mexico\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_Mexico\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_Mexico\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_Netherlands\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_Netherlands\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_Netherlands\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_Netherlands\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_Netherlands\InstallDir.cab
    !=> Failed to resolve Content\en\C3DCK_Norway\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_Norway\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_Norway\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_Norway\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_Norway\InstallDir.cab
    !=> Failed to resolve Content\en\C3DCK_Romania\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_Romania\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_Romania\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_Romania\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_Romania\InstallDir.cab
    !=> Failed to resolve Content\en\C3DCK_SouthAfrica\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_SouthAfrica\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_SouthAfrica\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_SouthAfrica\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_Spain\InstallDir.cab
    !=> Failed to resolve Content\en\C3DCK_Spain\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_Spain\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_Spain\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_Spain\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_Sweden\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_Sweden\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_Sweden\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_Sweden\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_Sweden\InstallDir.cab
    !=> Failed to resolve Content\en\C3DCK_Switzerland\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_Switzerland\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_Switzerland\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_Switzerland\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_Switzerland\InstallDir.cab
    !=> Failed to resolve Content\en\C3DCK_UKIE\AllUsers.cab
    !=> Failed to resolve Content\en\C3DCK_UKIE\PerUser.cab
    !=> Failed to resolve Content\en\C3DCK_UKIE\PerUser_Local.cab
    !=> Failed to resolve Content\en\C3DCK_UKIE\DataDir.cab
    !=> Failed to resolve Content\en\C3DCK_UKIE\InstallDir.cab
    Civil 3D 2013 (SP1)
    Win 7 Pro x64
    24Gb Ram
    Active Contributor
    justforthispost
    11-13-2012 04:15 AM in reply to: alison.gangler
    We are still having this problem, so no resolution as yet.
