We are experiencing a systems issue preventing some downloads from showing up in the Subscription Center. If this is affecting you, please use the following 72hr timed direct download links as a workaround until the problem has been resolved.
Autodesk Entertainment Creation Suite Ultimate 32BIT - LINK 1
Autodesk Entertainment Creation Suite Ultimate 32BIT - LINK 2
Autodesk Entertainment Creation Suite Ultimate 64BIT - LINK 1
Autodesk Entertainment Creation Suite Ultimate 64BIT - LINK 2
Autodesk 3ds Max Entertainment Creation Suite Standard 32BIT - LINK 1
Autodesk 3ds Max Entertainment Creation Suite Standard 32BIT - LINK 2
Autodesk 3ds Max Entertainment Creation Suite Standard 64BIT - LINK 1
Autodesk 3ds Max Entertainment Creation Suite Standard 64BIT - LINK 2
Autodesk 3ds Max Entertainment Creation Suite Premium 32BIT - LINK 1
Autodesk 3ds Max Entertainment Creation Suite Premium 32BIT - LINK 2
Autodesk 3ds Max Entertainment Creation Suite Premium 64BIT - LINK 1
Autodesk 3ds Max Entertainment Creation Suite Premium 64BIT - LINK 2
Autodesk Maya Entertainment Creation Suite Standard 32BIT - LINK
Autodesk Maya Entertainment Creation Suite Standard 64BIT - LINK
Autodesk Maya Entertainment Creation Suite Premium 32BIT - LINK
Autodesk Maya Entertainment Creation Suite Premium 64BIT - LINK
you may have to do this with all the suites
DarrenP
Hey Darren,
I don't think that all of the suites have been affected. Have you seen any or posts that would suggest otherwise?
not yet
some of the suites haven't been updated yet ex: Building Suite & Plant Design Suite
DarrenP
hopefully you won't have to do this with those suites
DarrenP
Darren, the 2013 Plant and Building Design Suite's haven't been released yet 🙂
DarrenP
Could you please make the downloads available here again as there seems to be continued problems with Subscription Center? Right now I need this:
Thanks!
Stefan
Hi Stefan,
did you get an error trying to download your Maya Entertainment Creation Suite Premium today? The links above expired and were not replaced as we had word that the issue in the Subscription Center had been completely solved; could you please confirm that you were unable to download the file from the Subscription Center today?
Meanwhile, I have updated the link for Maya Entertainment Creation Suite Premium 64BIT on the original post and you can also find it here. The link is fresh out of the oven and I just tested it to confirm it's working:
Thank you,
Hi Camilo,
Thanks for your quick reply! Yes, Maya ECS Premium is completely missing from my and my customer's Subscription Center account.
Thanks a lot for the link, I am downloading it now 🙂
/Stefan
Hi sorb78,
Can you please send me a Private Message (click on my philip.s user name, and then "Send this user a private message") with the email address or user ID associated with your Subscription Center login? I was unable to find an active subscription contract tied to your sorb78 profile.
