Installation & Licensing
Microsoft Visual C++ 2010 redistributable errors
3 REPLIES 3
1135 Views, 3 Replies
When I am installing Autocad mechanical 2012 I get the error shown in the attachment "error screen 1.doc".
So I try to manually run "setupdesignreview2012.msi" and I get the screen shown in "error screen 2. doc".  As you can see in the background, visual c++ 2010 is installed on my computer already, why is it telling me that it isnt?
3 REPLIES 3
TravisNave
Remove the 2010 C++ and try again.
http://forums.autodesk.com/t5/Test/How-to-take-a-screen-capture-and-upload-it/m-p/3467392
Autodesk Forums:
Already tried it multiple times.  Same error, same thing.
TravisNave
See my follow-up post about setup.ini here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Autodesk Forums:
Administrator Productivity
