Installation & Licensing
*Domínguez, José Israel Camper
Message 1 of 3 (75 Views)
Mechanical Network Problem.
75 Views, 2 Replies
05-23-2000 06:15 PM
Hi.
We reinstalled the adlm at the server, an IBM netfinity 5500, but the
mechanical client still can't get the authorization. After that, we
installed mechanical client at the adlm server but it didn't work
either.
At the adlm.log appears:
(EDITED FOR SECURITY)
Even though we set the ACADSERVER environment variable, the mechanical
client did'nt work at none of the machines; the variable
was settled like @system00.
They are using different protocols in the network:
DLC Protocol
NetBEUI protocol
NWLink IPX/SPX Compatible Transport
NWLink NetBIOS
TCP/IP Protocol
The machine is DHCP Server and PDC.
Also, the start time and the zombie timeout are 180 seconds and
verbosity is 9.
Thanks.
*milana, jerry
Message 2 of 3 (75 Views)
Re: Mechanical Network Problem.
05-26-2000 11:46 AM in reply to: *Domínguez, José Israel Camper
The first thing to do is make sure that TCP/IP is the primary protocol of
the AdLM server and all workstations. If your protocols are prioritized in
the order you list them in this posting, this will cause a problem. After
you have adjusted protocol priority, reapply your operating system service
pack. Then try again.
Please do nor post your messages multiple times any more.
Jerry Milana,
Autodesk Product Support
"J.I. Campero" wrote in message
news:392C2398.2653DFEC@dasoftmx.com...
> Hi.
> installed
> mechanical client at the adlm server but it didn't work either.
> 00-May-23 16:37:52: MX00238@system00 [0]: system00 lastping=959096255
> (UP).
> 00-May-23 16:37:52: MX00238@system00 [0]: RECV #1 RQ w.
> 00-May-23 16:37:52: MX00238@system00 [0]: Keydir set to E:\ADLM\KEY.
> 00-May-23 16:37:52: MX00238@system00 [0]: SEND #1 RP w SAR L 0
> TL 163.
> 00-May-23 16:37:52: MX00238@system00 [0]: -------------- LISTEN
> 00-May-23 16:37:52: MX00238@system00 [0]: bury_zombies: Too soon for
> next cleanup.
> 00-May-23 16:37:52: MX00238@system00 [0]: Packet from 10.91.1.1 (Local).
> TL 163.
> next cleanup.
> TL 163.
> 00-May-23 16:38:09: MX00238@system00 [0]: bury_zombies: Too soon for
> next cleanup.
> 00-May-23 16:38:19: MX00238@system00 [0]: bury_zombies: Too soon for
> next cleanup.
> 00-May-23 16:38:29: MX00238@system00 [0]: bury_zombies: Too soon for
> next cleanup.
> 00-May-23 16:38:39: MX00238@system00 [0]: BURY_ZOMBIES: Start.
> 00-May-23 16:38:39: MX00238@system00 [0]: BURY_ZOMBIES: Done.
> 00-May-23 16:38:49: MX00238@system00 [0]: bury_zombies: Too soon for
> next cleanup.
> 00-May-23 16:38:59: MX00238@system00 [0]: bury_zombies: Too soon for
> next cleanup.
> 00-May-23 16:39:09: MX00238@system00 [0]: bury_zombies: Too soon for
> next cleanup.
> 00-May-23 16:39:19: MX00238@system00 [0]: bury_zombies: Too soon for
> next cleanup.
> 00-May-23 16:39:29: MX00238@system00 [0]: bury_zombies: Too soon for
> next cleanup.
> 00-May-23 16:39:39: MX00238@system00 [0]: BURY_ZOMBIES: Start.
> 00-May-23 16:39:39: MX00238@system00 [0]: BURY_ZOMBIES: Done.
> DLC Protocol
> NetBEUI protocol
> NWLink NetBIOS
> TCP/IP Protocol
> verbosity
> is 9.
> Thanks.
*milana, jerry
Message 3 of 3 (75 Views)
06-16-2000 12:10 PM in reply to: *Domínguez, José Israel Camper
Jose,
As I have replied to your message on this site before, TCP/IP should be the
primary protocol of your AutoCAD systems and license server, if your
protocol priorities are set in the order of the list stated in this message,
problems are expected.
Also, please do not post parts of your log file on the news group, as it is
possible to expose undesired information about your network. In this case
the log information you include is not sufficient to analyze what may be
going wrong anyway. Try setting TCP/IP as your primary protocol, if that
does not help, I suggest you contact your MDT dealer. They can contact
Autodesk Product Support directly who will provide instructions on how to
create a log file with sufficient data for analysis and forward the log to
Autodesk.
Jerry Milana,
"José Israel Campero Domínguez" wrote in message
news:392B2D14.951F27B7@dasoftmx.com...
> Hi.
> either.
> DLC Protocol
> NetBEUI protocol
> NWLink NetBIOS
> TCP/IP Protocol
> verbosity is 9.
> Thanks.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
